Old 04-29-07, 06:08 PM   #1 (permalink)
big d 85 yota's Avatar
where does the oil go????
i have an 85 22rec that is going through oil like crazzy. about a quart every 100 miles. no leaks at all not one drip or oily spot on this engine or any of the drive train. its not in the coolant. this thing only smokes a little bit when you first start it or if you let it iddle a little while and stomp on the gas. what the hell??????
big d 85 yota is offline   Reply With Quote
Old 04-29-07, 06:09 PM   #2 (permalink)
cruiser88's Avatar
TLCA# 17319
rear seal maybe, crawl under your rig and check
Originally Posted by calstyl2 Randy has lots of junk.........
NEW! Club sticker for sale. See my avy...pm me for details!
MountaineerCruisers.net
Need a mini truck head for cheap?
http://forum.ih8mud.com/sale-parts/3...ini-truck.html
Old 04-29-07, 06:23 PM   #3 (permalink)
WristPin's Avatar
http://buy1.snapon.com/catalog/item....re&dir=catalog
this tool uses a fluid that you put in your coolant that reacts differently in ways you can determine your leak.
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
Old 04-29-07, 08:30 PM   #4 (permalink)
try a pcv valve
cruiserbent is offline   Reply With Quote
Old 04-30-07, 01:41 PM   #5 (permalink)
jhnLennon's Avatar
Had same problem with my 80 20r and my 81 22r.good compression,no leaks into the coolant,never did really figure it out.Even took head off and put new valve seals on it,didnt help any(all though that could be the problem with yours.)I suspected bad oil control rings. Do a compression check,and a leakdown test if you can.If it smokes a litle blue at start up and when you let off the gas after heavy acceleration than it is your valve seals.Had an old chrysler 318 that was using a quart every 100 miles and replaced valve seals and didn't burn a drop.(Big problem with old motors that used umbrella seal for valves,toyota does use a positive type valve seal though that lasts much longer)
jhnLennon is offline   Reply With Quote
Old 05-01-07, 11:18 PM   #6 (permalink)
Rookie
Hmmm, I think I'm the same boat.
Trouper is offline   Reply With Quote
Old 06-06-07, 03:11 PM   #7 (permalink)
changed pcv no diffrence.
Old 06-06-07, 04:25 PM   #8 (permalink)
dizzidave's Avatar
I had the same problem until it snowed, then I figured out quick where it was goin...right out the tail pipe.
dizzidave is offline   Reply With Quote
Old 06-06-07, 08:40 PM   #9 (permalink)
WristPin's Avatar
take out the plugs. see if they are all oil fouled or just one. this will help you determine what cylinder(s) is consuming.
addtionally, when it sits overnight, the valve stem seals leak oil down the valves and ultimatly into the combustion chamber. causing the smoke at initial startup.
Wristy
Jebus...
Old 06-09-07, 01:55 PM   #10 (permalink)
Back in 85 I was working at the local Toyota dealer and we had LOTS of this same complaint. On the 85's the new piston design did have a few issues( flexing= resolved in 86) and the main problems were bore taper and out of round and rings lining up causing lots of oil consumption. Ihave personally done over 250 of these jobs about 3/4 under warrenty. Check your compression and do a cylinder leak down test . This may help with the diag.
billstoyshop is offline   Reply With Quote
Old 11-05-09, 09:08 AM   #11 (permalink)
meatloaf's Avatar
I have the same problem, except that I can go around 200 miles without have to add a quart...
How do you do a leakdown test?
83 FJ60
92 4X4 x-tra cab 22RE
Meatloaf®
meatloaf is online now   Reply With Quote
Old 11-06-09, 10:50 AM   #12 (permalink)
Chop Shop's Avatar
just face it, you have a 22r thats WORE OUT
add oil or rebuild it. It probably is making the guy behind you on the trial sick anyways. (cough cough)
if a 22r is not new or rebuilt it will smoke or knock or both.
Ive killed many many 22r/res
Chop Shop is offline   Reply With Quote
Old 11-06-09, 03:48 PM   #13 (permalink)
meatloaf's Avatar
How much does a rebuild cost or where can I get one already rebuilt?
Here's my dumb question for the week:
Don't think so, but, is there such thing as the exhaust smelling like burnt oil without the smoke?
TIA,
ML
83 FJ60
Meatloaf®
Old 11-06-09, 11:38 PM   #14 (permalink)
Not on a 4-Runner but on another vehicle of mine, when it started to use oil it turned out to be the valve stem oil seals.... not being a mechanic, could it be this on your vehicle?
PJHunter is offline   Reply With Quote
Old 11-06-09, 11:56 PM   #15 (permalink)
Chop Shop's Avatar
TIA,
ML
It may be so wore out it doesnt have enough compression left to actually burn the oil (making smoke) and just puke caustic fumes that make a person sick.
