Old 04-21-07, 11:36 PM   #1
2rivers's Avatar
steady bearing / grease question
Hi,
Might be a dumb question but do you grease the inside surface of the steady bearing before you put it on the mating driveshaft surface or should it be a dry fit?? I greased it but I think I maybe shouldnt have
Really appreciate knowing what is "correct" as I got some kind of squealing going on underneath there... (I did torque the stake nut to correct lbs).
Thanks,
Johnny
82 BJ60 "Old Blue" plow truck - she's a beauty!
Fleet of JDM goodness
97 Yamaha Enduro
55 Case 500 Diesel tractor
73 JD 500C backhoe
2rivers is offline   Reply With Quote
Old 04-21-07, 11:39 PM   #2
No longer pre-approved...
2ndGenToyotaFan's Avatar
Are you talking about the center bearing in the rear drive shaft? If you greased it and it wasn't suposed to be greased, I doubt that it would be squeeking.... that's what non greased things do...
Old 04-22-07, 10:09 AM   #3
2rivers's Avatar
Wondeering basically should it be a tight pressure fit, or is there some slip? The new bearing went on with ease and I thought if it spins it will turn blue fast - so I greased it. Agreed sqeeling likely not coming from here....
anyone?
97 Yamaha Enduro
73 JD 500C backhoe
Old 04-22-07, 10:10 AM   #4
2rivers's Avatar
yes, this is the centre bearing in the rear driveshaft
thanks,
Johnny
97 Yamaha Enduro
73 JD 500C backhoe
Old 04-22-07, 02:23 PM   #5
When does the noise happen? All the time while moving, only at certain speeds?....
Old 04-22-07, 11:10 PM   #6
2rivers's Avatar
HAppens when I'm first startinig out - say in the am or afterwork - and does it for approx 1 minute until I get the truck up to speed/ rev it up once or twice. I dont think it is the fanbelt, but it sounds like that.
I'll fool around a bit more.....just cant help wonder about greasing that damn driveshaft to fit inside the steady bearing...
Thanks for your reponses 2nd GEn!
97 Yamaha Enduro
73 JD 500C backhoe
MPAA | Cheap Books | Loans | Free mobile phone's stuffs | Online Loans
