Old 04-12-07, 11:20 PM   #1
WristPin's Avatar
Failing Emmissions Checklist
If you are failing the emssions test, the print out they give you with the parameters, and your specs, together, will be helpful to determine the cause of your problem.
HC CO SYMPTOM CAUSES
High Normal Rough idle-------------------1. Faulty Ignition:
-----------------------------------------Incorrect timing, shorted or improperly gapped plugs,
-----------------------------------------Open (cracked) or crossed plug wires, Cracked distributor cap
-----------------------------------------2. Incorrect valve clearance
-----------------------------------------3. Leaky EGR valve
-----------------------------------------4. Leaky Exhaust valves
-----------------------------------------5. Leaky cylinder
High Low Rough idle with fluctuating HC reading 1. Vacuum leak:
-----------------------------------------Vacuum hoses, Intake manifold, Intake chamber
-----------------------------------------PCV line, Throttle body
High High Rough Idle with black smoke from exhaust 1. Clogged air filter
------------------------------------------2. Plugged PCV valve
------------------------------------------3. AS system problems
------------------------------------------4. Faulty EFI system:
------------------------------------------Faulty pressure regulator, Clogged fuel return line
----------------------------------------- Faulty air flow meter, Defective water temp sensor
----------------------------------------- Defective air temp sensor, Faulty ECU ( not typical)
----------------------------------------- Faulty injector, Faulty cold start injector
Wristy
Jebus...
WristPin is online now   Reply With Quote
Ringtone | Cell Phones | Loans | Machine Tools | Credit Card Consolidation
