79-95 Toyota Truck Tech Covering the minitruck/hilux, surf, and 1st/2nd Gen 4Runner
Old 03-01-07, 09:19 PM   #1 (permalink)
Urban Offroader
PurpleFJ62's Avatar
Camber Adj
Has anyone adjusted the Camber on their 4runner before? Do you have to take the camber adj bolt and nut completly out? Should I seperate the nut and bolt, or are you to turn them at the same time?
How tight are these bolts uasually, is it ok to put a substancial force on them to bust them loose?
thanks-nate-
PurpleFJ62 is offline   Reply With Quote
Old 03-01-07, 11:02 PM   #2 (permalink)
ajfriz's Avatar
mine were very stuck. The best way to do it is to have a shop do it. I work at a shop that has an aligner. It is very touchy so I would just bring it to them. To answer your question, there should be eccentrics (sp?) that you need to turn to adjust it. You need to loosen the bolt and then turn the eccentric to the desired position.
1978 FJ40 283 v8-sold :(
1986 4runner SAS and stuff
ajfriz is offline   Reply With Quote
Old 03-01-07, 11:03 PM   #3 (permalink)
WristPin's Avatar
+1
take it to a shop.
Wristy
Jebus...
My shop
22RE Tech hotline- check the FAQ
Old 03-02-07, 12:43 PM   #4 (permalink)
Symon623's Avatar
Originally Posted by WristPin View Post
+1
take it to a shop.
X2.....do them a favor and hose em down with penetrating oil a couple of days ahead of time.
Sy
85 Syota - 4.3/700r4/300/60's
High Country Renegades/ARC
http://www.4wdhqs.com/
Symon623 is offline   Reply With Quote
Old 03-02-07, 04:28 PM   #5 (permalink)
Urban Offroader
PurpleFJ62's Avatar
its done. when I picked it up this afternoon I had a conversation with the owner for a little while. Talking about how messed up the underside is. Said he had the bolts/nuts cherry red with a big long breaker bar on it. I should have soaked in P.B. blaster. I wasent thinking ahead.
