Old 03-28-07, 08:41 AM   #91 (permalink)
M3TAL D0RK's Avatar
Thumbs up
the ride is waaaay soft. when he hits the brakes the front dips at least a foot. its pretty funny actually. you gunna need to trim the rear at all?
Josh.
minis kick ass. i got some toyota junk.
www.myspace.com/m3tald0rk
M3TAL D0RK is offline   Reply With Quote
Old 03-28-07, 10:18 AM   #92 (permalink)
4RUNNY's Avatar
TLCA# 16548
nice work.
'89 SNOWRUNNER
4RUNNY is offline   Reply With Quote
Old 03-28-07, 03:02 PM   #93 (permalink)
Josh.
Yeah I Think So, And Some Of The Front Fender As Well, I Can Hear The Tires Rub When I Make A Sharp Turn.
Drove To Salt Lake Today, For Some Classes. Right Was Awesome. I Need To Check A Few Things Out Tonight When I Get Off Work. I Think My Pinion Nut Is Coming Loose, Or My Drive Shaft Is Not Long Enough. I Guess We'll Se Huh.
Full_M3tal is offline   Reply With Quote
Old 03-29-07, 01:29 AM   #94 (permalink)
Well I Checked The Nut And Its Fine, I Think Its Just Vibration Of The Drive Shaft.
So I Am Going To Order A 3 Hole Spring Plate And Move My Axle Forward. This Will Also Help With The Tire Rub, And Not Having To Cut Out To Much.
Bullets For Blood
I Like Caps!
http://www.worldwideoffroad.com/
MyBuild Up:
http://forum.ih8mud.com/showthread.php?t=140640
Old 03-30-07, 01:32 AM   #95 (permalink)
projektdotnet's Avatar
Originally Posted by 2badfjs View Post
i see projectdotnet standing around in one of those pics.....does he actually do anything?
Hey I did hold a shock in place, and run to the fridge to grab the rest of the guys drinks
Dude that thing is way better lookin than when I left sunday afternoon
"Those who would give up essential liberty to purchase a little temporary safety, deserve neither liberty nor safety." -Benjamin Franklin
projektdotnet is offline   Reply With Quote
Old 03-30-07, 10:13 AM   #96 (permalink)
M3TAL D0RK's Avatar
so whens the hydro steer comin. got anything else planned
Old 03-31-07, 12:16 AM   #97 (permalink)
Hydro I Have, I Am Just Looking For A Steering Box So I Can Rebuild It, And Drill And Tap The Holes For The Lines.
We Just Got Our Pump For Our Bender, Just Need Hydro Fluid.
And I Will Be Building A Beteer Front Bumper With Stinger.
Still Designing Exo Cage.Just To Let You Know On How Tall It Is....
30" From Ground To The Bottom Of The Frame.
7' From Ground To Top Of Roof.
I Am 6'5" And Have To Jump In To Get In.
Sunday I Will Be Moving The Rear Axle Forward An Inch.
Tuesday I Am Going To Tom Woods To Get A Price On My Drive Shafts.
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-03-07, 12:59 AM   #98 (permalink)
Ok Well I Have The Exo Cage Moslty Designed, Just Need To Take Alot Of Meassurements So I Can Build One In Bend Tech Bro ( A Program We Have For Desinging Cages)
I Am Also In The Process Of Getting A Power Steering Box From 2ndGenToyotaFan. Thank You!
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-03-07, 09:14 AM   #99 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
I wasn't going to do anything with it.....
Old 04-03-07, 02:29 PM   #100 (permalink)
buffethat@comcast.ne's Avatar
Did you have any problems installing the Hi steer? Mine will not fit the Trunjan bearing or knuckle bearing. Got new bearings coming but do not think it will make a difference, I think the steering arms are a tiny bit to big. if so I will have to have them ground down.
Your build looks great, doing about the same thing but started with a straight axle already. Have some loose ends to tie up and hope to be done in a week or two on time for CM07
Thanks Tom
1985 4Runner(again) Marlin crawler Ult. 5.29 with Elockers frt&rr, High pinion front with custom axles JPR motor with headers into 2.25 exhaust Marlin lift on 37's and a ton of other goodies.
TLCA #6136
DD is a 2005 GMC Crew Cab 4x4 loaded.
buffethat@comcast.ne is offline   Reply With Quote
Old 04-03-07, 06:17 PM   #101 (permalink)
I Really Didn't Have Any Problems With The High Steer. Sometimes The Wont Slide In Like Butter. So I Used A Little Bit Of My Synthetic Grease On Where The High Steer Goes In The Trunjan Bearing. And Just Hit It In With A 2 1/2 Pound Hammer.
Also On The Tie Rod Ends I Had To Use A Air Gun To Get Them To Come Down Just Enough Where I Got Some Tire Wire Through Them.
I Was Planning On Building It For CM07, But I Have To Pay Bills, So I'll Be Testing It In The meen Time To See What Breaks, And Holds Up.
I Do Plan On Going To CM08.
So I Went To Tom Woods Today, Found A Shaft In Our Shop That Will Work. Just 3" To Short. They Say It Will Be Done Tommorow. For A Cost Of 100$.
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-04-07, 11:16 AM   #102 (permalink)
What did you use parts wise for the front brakes? I am getting to upgrade them and have heard some conflicting stories. Need to get the correct info so I can get the parts lined up.
I am still waiting for the trunjens to come in, once in I will be able to finish the front. Got the tank back in and the rear is just about done, E brake and brake line left to go.
That was a nice deal on the drive shaft not to bad of a price indeed.
Thanks Tom
TLCA #6136
Old 04-05-07, 12:00 AM   #103 (permalink)
Front Brakes I Used My IFS Calipers, And The SAS Came With New IFS Rotors.
If You Have 79-85 Toyota That Has The Solid Axle. You Should Be Fine With What You Have.
aslo do yuo have a build up page?
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-05-07, 04:41 PM   #104 (permalink)
That is what I figured. I have the rotors but need to find some calipers. I like the vented rotors better but more importantly I plan on getting the larger master cylinder to match the rear end.
I don't have a build page, I started and forgot to take pictures. Now I am to late.
Thanks Tom
TLCA #6136
Old 04-06-07, 12:39 AM   #105 (permalink)
Do You Have A Stock Rear End?If You Are Going Discs In The Rear, Look For A Land Cruiser Master Cylinder.Infact I Think I Might Have One. I'll Have To Look Saturday. It Matches Right Up With The Mini Truck Booster. We Have 2 LC That Have Chevy Discs. So It Should Work Fine.
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-06-07, 09:55 AM   #106 (permalink)
I have an 87 rear end from a truck. It has been reworked to fit an E-locker in it. My first thing to buy will be the calipers then the Master, some new brake lines so I can move some things around. Right now it is not a priority to get done but once the 37's are on it I am sure I will need something better to stop this bad boy (once it is done :-)
Let me know about your MC I may have some cash left to get it, I am about $1200 over budget but then again that is normal for me.
Thanks Tom
TLCA #6136
Old 04-06-07, 01:42 PM   #107 (permalink)
Oh nevermind......
TLCA# 13872
I'm pretty sure 1200 over budget is still under budget when it comes to building a trail rig...
Old 04-06-07, 05:33 PM   #108 (permalink)
I would agree with you but that was only the suspension. That is not including the front bumper and rear carier. I did buy some extra things like seals and bearings for the front since I had free shipping.
I hope to be done late Sunday afternoon with all the work. Then the drive shafts will need to be build and an alignment. All in all I think I should be able to drive it next weekend, I can't wait.
Thanks Tom
TLCA #6136
Old 04-06-07, 09:20 PM   #109 (permalink)
Ok.. Awesome.I Know How You Feel Man, I Couldn't Wait To Drive Mine.... And I'm Loving Every Moment Of It.
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-06-07, 10:41 PM   #110 (permalink)
That thing came out sweet
Old 04-23-07, 12:25 AM   #111 (permalink)
UPDATE!
Ok So We Went To The Rattle Snake And Constrictor In Northern Utah.
Heres A Few Action Shots....
I Also Put A Anti Wrap Bar On The Front. And Was Not Thinking At The Time When I Made It.
I Put It Coming From The Rear Of The Axle To The Crossmember For The T-Case. And Bent The Poopie Out Of It.
So I Took It Off And Cut It Up. To Make A New One.
Did Some Research And Found One The Comes From The Front Of The Axle Up To The Front. Its Called A Slip Bar Traction Bar. Makes It So You Dont Need A Shackle At The End.
So I Went Scavageing Through The Shop And Found Parts That Would Work.
Parts List-
2" 120 Wall Tubing
1 1/4" 1/2" Wall Tubing
1981 Toyota Drive Shaft.
I Didn't Have My Camera Because My Brother Has My Memery Card And He's In Hawaii Right Now. So As Soon As He Gets Back I'll Post Some Picks Of It....
Heres A Mock Up Picture I Made On Paint....
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-23-07, 12:49 AM   #112 (permalink)
Heres One More Action Shot On The Eagles Nest. Shows It A Little Better ( I Kinda Bent My Bumper).
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-23-07, 08:34 AM   #113 (permalink)
Looking good man, I wish I was there with you guys. I want/need to wheel my truck so bad but have had the time to do so. Leave for Mab in a week and the springs are still stiff.
I like the anti wrap bar you are building, let me know how it works out. I am thinking I need one for the rear, got some axle wrap going on there. Not sure if I will build something or just buy a pre made one. The front seems OK for now but that can change as the springs loosen up a little.
I like the last shot, looks great and who needs a stock rear bumper anyway??
When you get the camera back, memory card, take some pics of the traction bar anxious to see how you will mount it and how it looks.
Thanks Tom
TLCA #6136
Old 04-25-07, 07:03 PM   #114 (permalink)
Arya Ebrahimi's Avatar
If you use the slip yoke for the slide part, you will EAT bushings at the frame end because all of the twist of the articulation is forced through that bushing. You need to find two pieces of tube that slip nicely together but are not splined.
Ary
HOKIES UNITED
Mobile Base Camp Trailer Build
Arya Ebrahimi
'94 FZJ80 220k miles, locked, 4.88s, 285 Revo's, ARB Bullbar, Hella 4000's, homemade drawers
'86 Toyota Pickup SAS'ed, welded, 4.88s, 38 TSLs, and lots o' tube
Arya Ebrahimi is offline   Reply With Quote
Old 04-25-07, 08:29 PM   #115 (permalink)
Have another question for you, what is your frame height? Are you running 37's ot 35's can't remember. Just curious how mine compares to others out there. Got both front and rear lockers working today and took it out to the field tonight, somebody drop a bunch of cement/rock out there, perfect posing/flexing hill. Engaged the lockers and felt the front pull straight right away. So happy I got that worked out.
I will post a few pictures soon, just want to get some other things done first. I did manage to mount the sliders and cut the rear fenders for clearance. She is looking good, can't wait to see how she looks with red rocks as a background.
How is the traction bar going???
Thanks Tom
TLCA #6136
Old 04-26-07, 10:25 AM   #116 (permalink)
Ary
I Have A Flex Joint (It's Like A Johnny Joint) On The Slip Yoke End. Then Just The Regalur Bushing On The Axle
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-26-07, 10:31 AM   #117 (permalink)
Frame Height Is 29 Inches With 37". But I Got Pulled Over So I Will Have Get Some 29" Tall Tires To Meet The Reqiure Ments Of The Road.Traction Bar Is Done And Works Great. I Post Some Pics Up This Weekend.And Sunday Night I'll Post Picrures Of Little Moab Near Lehi
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 04-26-07, 10:54 AM   #118 (permalink)
Sounds good, sucks that you have to go to "little" tires to drive around town. I would see if you have any other options, maybe get it passed as a truck or pay off the state patrol guy
I 'll look for the pictures of the traction bar, be cool to see it in action.
Good luck in Little Moab, 6 days and counting before I get to feel the traction of slickrock, can't wait of the walls her at work.
Thanks Tom
TLCA #6136
Old 04-28-07, 02:52 AM
hogami
This message has been deleted by Gumby.
Old 05-03-07, 02:32 PM   #119 (permalink)
Front Anti Wrap Bar:
<p></p>
<p></p>
<p></p>
<p></p>
<p></p>
<p></p>
Bullets For Blood
I Like Caps!
MyBuild Up:
Old 05-03-07, 03:59 PM   #120 (permalink)
Oh nevermind......
TLCA# 13872
Interesting, lets see some test pics!
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/140640-full_m3tal-build-up-86-4rnr.html
Posted By For Type Date
Full_M3tal's 1986 4RNR - Utah's Rock Crawling and Off-Road Forum This thread Refback 10-22-08 08:52 AM
