Old 02-28-07, 09:51 AM   #1
PurpleFJ62's Avatar
4runner front wheels squatting after sway bar removal
My front wheels are now squatting after sway bar removal, does anyone have any tips? thanks -nate-
PurpleFJ62 is offline   Reply With Quote
Old 02-28-07, 10:47 AM   #2
No longer pre-approved...
2ndGenToyotaFan's Avatar
The sway bar has nothing to do with holding the front of the truck up. It only keeps it level side to side. Is this about a truck/4Runner or your 62?
Old 02-28-07, 12:31 PM   #3
bkg
define "squatting," please.
Brian K. Gallus
bkg is offline   Reply With Quote
Old 02-28-07, 12:57 PM   #4
KLF
KLF's Avatar
Hopefully by "swaybar" they don't mean "torsion bars".
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
KLF is online now   Reply With Quote
Old 02-28-07, 01:00 PM   #5
Ewwwwww.... Oh !!!
:fingerscrossed: .......
Old 02-28-07, 05:08 PM   #6
And explain when it happens, when you drive it, hit a bump, or if it's just plaine sitn'
tntoyota is offline   Reply With Quote
Old 03-01-07, 02:15 PM   #7
PurpleFJ62's Avatar
I just replaced the ball joints and shocks. As well as CV boots and such. After I am done putting it back together I leave the sway bar off. I do not have the parts needed at that time to finish that part of the job. Anyways so after I got the wheels back on and set the front end down on the floor its apparent that the botton area of the tires are farther apart than the upper area of the tires.
The wheels are not perpundicular to the ground. This is not good, because this is my winter beater and now my 62 is getting salt on it. My 62 does not like salt very much.
Old 03-01-07, 02:55 PM   #8
bkg
when you replaced the ball joints, did you remove the lower a-arms? Cause it sounds like you are WAY out of alignment....
Brian K. Gallus
Old 03-01-07, 03:27 PM   #9
PurpleFJ62's Avatar
lower A arms were not removed. However I was hitting a pickle fork with a sledge hammer to pop the ball joints out. But then I was hitting it was towards the engine. So if the A arms came out of alignment I would suspect to have my alignemt situtation reversed, so the bottom of the tires are closer than the tops. I don't think you can do an alignment in your barn on the floor can you?
Do people go to the dealers for this?
How does the pivot point of the lower A arm stay "true" and not change. Is this just a matter of loosing a bolt and nut and playing with it until its right?
thanks for any help.
Old 03-02-07, 12:03 AM   #10
I can't remember, is there a wrong way to put the ball joints in? I don't think so. If not, then you may just need an allignment......
Old 03-02-07, 12:08 AM   #11
WristPin's Avatar
no you cant. the bottom ones are round, and the top has four bolts that only fit one way.
you need to take it in and spend the 50 bucks to get it alinged
Wristy
Jebus...
WristPin is online now   Reply With Quote
Old 03-02-07, 10:15 AM   #12
bkg
I concur. However, unless his camber bolts were loose, there is really no way this should have have come out of alignment this far UNLESS his old ball joints were that shot... I'd like pics.
Brian K. Gallus
Old 03-02-07, 05:22 PM   #13
PurpleFJ62's Avatar
I am computer stupid and can barley even type the words that you guys are reading. However I do have a digital camera, and kinda know how to use it. I saved the old ball joints and could show them if I could get some help setting up a photo account.
-nate-
Old 03-02-07, 05:24 PM   #14
PurpleFJ62's Avatar
forgot to say I did get it aligned this morning, it is not perfect, I was told the adj. cams were maxed all the way in. Not exactly shure why whatever I did changed the steering geometry that much.
is there a place to get used/new A arms and knuckles, theres not much left of mine.
thanks again...
Old 03-02-07, 06:27 PM   #15
WristPin's Avatar
-nate-
go to www.photobucket.com and register. its easy to do. all you need is a email. once you log in you can upload pics. its easy
Wristy
Jebus...
Old 03-02-07, 08:55 PM   #16
Put up a want ad in the wanted section, I'm sure someone has all their IFS stuff from a SAS lyin' around.....
Old 03-03-07, 01:32 PM   #17
PurpleFJ62's Avatar
that is an option. The fella at the alignment shop said how he felt that 4runners last alot longer than most of the suvs he services. Currently we are at a crossroads, me and my dad that is. It is his 4runner, I just work on it for him, and he helps with it now and then. He dosent want to really save it, rather drive it until it dies.
If I could find some clean parts locally that would be good, but this thing needs body work. Are 2nd gens famous for rusting out. And dont get me started about the rear tailgate design, thats where the 3rd gen really has the 2nd gen beat. Besides the engine.
I have found front door shells for 150 online, but I also need rear doors as well. Is there an aftermarket tailgate for these things, something that is built a little better and will not rust?
-nate-
Old 03-03-07, 03:02 PM   #18
They rust at the wheel wells, the bottom of the rear 1/4's and the bottom of the tail gate usually..... You live in MI though..... so if you fix it, it will come back. Do you have any pics of how bad it is?
Old 03-03-07, 04:18 PM   #19
PurpleFJ62's Avatar
let me try to get a account at this photobucket thing, then you will see.
Old 03-03-07, 04:35 PM   #20
PurpleFJ62's Avatar
Old 03-03-07, 04:36 PM   #21
PurpleFJ62's Avatar
shit!!!
Old 03-03-07, 04:38 PM   #22
PurpleFJ62's Avatar
help.....................
Old 03-03-07, 04:49 PM   #23
Oh Hell! Those aren't even holes yet!!!! What are you whining about?
I say give repairing them a shot.
Old 03-03-07, 04:51 PM   #24
cruiser88's Avatar
TLCA# 17319
a new aftermarket bumper to get rid of that rust,and for heavens sakes take off those mudflaps.they are rust magnets.and yea just repair that panel, does not look bad
ByPhilC64
Dig the anger on on the bacon sammich chaser. You being angry is like Boy George not trying to be gay. Go play with your 2 inch line, some hand cream and a sock. You'll feel better.
Old 03-03-07, 05:17 PM   #25
PurpleFJ62's Avatar
you can see the pics, I cannot. And yes the rust is bad, very bad, and in the last couple of winter months here in michigan have made alot of those rust patches into full blown holes. Does anyone have any clean rear doors for sale?
Old 03-03-07, 05:21 PM   #26
cruiser88's Avatar
TLCA# 17319
you may want to try ttora its another toyota site like this but they have alot more minis,tacos and such.thats where i bought my four runner threw
ByPhilC64
Old 03-03-07, 05:22 PM   #27
cruiser88's Avatar
TLCA# 17319
here ya gothats if nobody chims up here on mud
ByPhilC64
Old 03-03-07, 05:24 PM   #28
cruiser88's Avatar
TLCA# 17319
http://www.tacomaterritory.com/ sorry
ByPhilC64
