Old 02-27-07, 09:05 AM   #31
bkg
Originally Posted by Bear80 View Post
It is notched to fit a certain way and should not be able to be re-clocked. Only the rear anchor is this possible on. I've had both anchors off and test fited them when I was using stock t-bars with my new setup. I for one would not do this because the weak link is the anchor splines and people have broke them with just the lack of grease.
Yes, there is a single notch in the splines on the a-arm side of the TB. It's just a missing spline on the torsion bar; cut another spline out of the TB and call it good. Not a big deal to remove another spline for a mildly wheeled vehicle. I've done this before and it has worked fine for 5+ years.
The a-arm anchors themselves can break, but we're not talking about modifying them.
Brian K. Gallus
bkg is offline   Reply With Quote
Old 02-28-07, 03:41 PM   #32
odtseuss's Avatar
TLCA# 12676
warning thread hijack
Bear80 where did you get those adjustable tie rod links/sleeves with the jam nuts? could you post a close up pic of the ball joint spacers? I'm curious, whats the suspension setup on this truck?
Set at aprox. 3" of lift, a full 12" of wheel travel and I have it set to 1" less drop than compression. Not to mention I still have the stock track width:
odtseuss is offline   Reply With Quote
Old 02-28-07, 05:04 PM   #33
I think they came with the Rancho front along with a very heavy relay rod
I think,
I would love to get a P# and manufacturer for those parts.
tntoyota is offline   Reply With Quote
Old 03-01-07, 10:49 AM   #34
thanks for everyones help
pcpnna is offline   Reply With Quote
Loans | Cheap Samsung LCD TV | Mortgages | The eBay Song | MPAA
