axle question
Local junkyard has 94 4Runner. Will rear diff fit in my 87 p'up axle that I plan on installing in my 85 4runner? I have heard all v6's were 4.56. What is gear ratio? Will complete axle assembly fit. I have also heard that on solid axle mini's that the front & rear diff's are interchangable is this true?
Diff will not work. You could use the entire axle, but the 94 Runner has coil springs, so you would have to cut off the coil buckets and weld on spring perches (assuming you're running leaf springs). R&P selection is much more scarce (and expensive) for that diff as well.
Front and rear diffs are interchangeable on solid axle trucks. __________________ "Inside every old person is a young person saying "What the F*** happened?" Bob 95 FZJ80 83 Mini-Truck Tornado Alley Cruisers Shawnee, KS |
#3 | |
A V6 DIFFERENTIAL (not the axle) will bolt right into an '87 rear axle housing. As for the ratio, there are several choices that the factory put in the 2nd gen 4Runners: 1:4.10, 1:4.56, and 1:4.88. You can look at the VIN tag on the firewall to read the axle code and get the ratio, or if the diff is already pulled out, just count the teeth. The only diff that has an odd R&P is the 4.88's, they are weird, different carrier too. I don't think there's any lockers available for it. Unless you want to stick to this ratio forever, I would avoid it. But for the others, there are plenty of choices for R&P ratios. __________________ KB1OSF '87 Toyota xcab SR5 - SAS'd, stuff '98 Lexus ES300 '04 Toyota Highlander |
Not if the 87(what?) is a 2wd.
any other what ^^^^^^^^^^^^^^^^^^^^^^^said My formula is (79-95 only 2MK) aw, forget it to detailed and to much can "ReQuired Reading" be put into FAQ Newbies sticky thread etc. REQUIRED READING::::L.C enginering, Downey, Toyota truck and LC owners bible, NorthWest off-road specialties, A.Adapters Buyers Guid (F*R*E*E*) ah.....Chilton's manual 2, 70-88 and 88-96? FSM's get'em...... ALL 8" centers have the same bolt pattern 2wd is 7.5" V6 is 33% bigger, heavyduty Buy the 4r rear then buy another one cheaper than regearing. put one in the frount diff go wheelin' with your cheap HD 4.56's tell ever one you know this with any luck you WILL NOT be able to buy another one ever again P.S you might need the 2" you are doing away with to get between an obstical for that IFS rear mod. Last edited by tntoyota; 02-26-07 at 02:03 AM. |
I think we need to ask Woody to install a translation engine on the server, so we can understand your posts.
yeah i cant read that either
![]() I'll start a new thread Diffs-4-Dummies It took me four years to learn what I'm saying those books will tell you as soon as you get them. Last edited by tntoyota; 02-23-07 at 10:04 PM. |
#7 | |
most likely if it were a v6 automatic, it had the 4.87 gear ratio- this will work in a early model axle housing.
KLF is correct, there is no aftermarket support for this 3rd member, you will onlybenefit from the lower ratio... NO traction adding devices (detroit, trutrac,ARB, Etc) and yes the same third will fit in the "7.5" housing, only the third member is smaller.... been there done that. The ignore button does work, you dont have to translate gibberish that has no place/merit in a tech forum. __________________ New and Improved now with 100% more horsepower, 70% more torque and 4.1 Low range!
No longer pre-approved...
Axle code info:
http://toyota.off-road.com/toyota/ar....jsp?id=274535 and more here: http://www.4crawler.com/4x4/4R_TechI...#Differentials __________________ Jerod Online Toyota Parts Catalog!!! 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
#10 | |
http://video.google.com/videoplay?do...q=land+cruiser Last edited by tntoyota; 02-28-07 at 05:17 PM. |
#11 |
Uhmm what's with the video?
#12 |
Keep refreshing or x it then go back
Some times it works best thing is to go to Google Vidio search for Land Cruiser It's on page two about 3 down Last edited by tntoyota; 02-28-07 at 05:33 PM. |
Discount Computer Speakers | Personal Finance | Problem Mortgage | Vacation Spots | Online Advertising |
