Old 02-12-07, 12:03 AM   #1
Jonathan_Ferguson's Avatar
TLCA# June 9th, 2002
Cigarette Lighter Removal
How do I unclip the Cigarette Lighter section?
Or, is there somewhere else I can get Power on with the Ignition?
1986 Nuclear Reactor
1985 Toyota LN65R
LIFE AIN'T WORTH LIVING WHEN YOU DIE BEFORE YOU'RE MEANT TO!
Jonathan_Ferguson is offline   Reply With Quote
Old 02-12-07, 01:10 AM   #2
No longer pre-approved...
2ndGenToyotaFan's Avatar
Pull out the ashtray, pull the three screws that hold the metal thingy in above the ashtray, pull the 2 screws that go in the sides at the bottom front of the center thing. (by your leg, and the pass leg...) it should pop out enough to get to the back of the cig lighter.
Old 02-12-07, 01:12 AM   #3
Are you just looking for switched power? You can pull the bottom off the steering shaft cover and test the wires that run down into the dash and see what's switched with a meter/light....
coupon-coupon.com | Loan | Fish Tank Help | Shops 2006 | Anime Downloads
