Old 02-10-07, 04:31 PM   #1
valentine's Avatar
Header install
'84 22R
What's the pipe that runs across my exhaust manifold & ties into it across the top?
I want to install a header this weekend & want to know if I can just plug it off, or if it needs to stay.
TLCA # 11402
97 FZJ80
87 Land Cruiser FJ60
84 Toyota long bed P.U.
"The truth is NEVER hate" dieseldog 10-21-06, 11:00 PM
I am the Shadow Ninja
TUTotals
Originally Posted by Lupdog View Post
It's great to be a public nuisance!
Originally Posted by rachel1027 View Post
I would do her.
Originally Posted by semlin View Post
i don't want my tall dinner guests playing footsie with the people across the table
tall people are not trustworthy that way
Originally Posted by Jman View Post
Suck, squeeze, bang, blow.
You need more in your sig line
valentine is offline   Reply With Quote
Old 02-10-07, 04:34 PM   #2
Thats your EGR (exhaust gas recirculator)
dirtoyboy is offline   Reply With Quote
Old 02-10-07, 04:50 PM   #3
valentine's Avatar
That's what I was thinking, but wasn't sure
The header doesn't have any way to connect the egr pipe, are there any pro's/con's to removing it plugging it off at the egr valve?
As y'all can see, I'm clueless with the emissions systems.
TLCA # 11402
97 FZJ80
TUTotals
I would do her.
Old 02-10-07, 05:35 PM   #4
Yota Tony's Avatar
Without it you might (or will) fail emissions.
Not sure if there's anymore set backs.
Yota Tony is offline   Reply With Quote
Old 02-10-07, 11:35 PM   #5
ajfriz's Avatar
There are a ton of different models of headers for the 22r and 22re. I used to sell them for a company and we would have to know a few things about the egr and 02 sensor placement. I am pretty sure that thorley offers a header that will still allow you to run your egr so that you can still pass emissions. They are a 50 state legal header company.
1978 FJ40 283 v8-sold :(
1986 4runner SAS and stuff
ajfriz is offline   Reply With Quote
Old 02-11-07, 12:31 AM   #6
valentine's Avatar
I did see those somewhere on the net, but I got the complete exhaust system including the headers for free from a buddy that had it on his '84 before he started his small block swap.
The headers don't have any outlets for the egr. I won't install it if it's going to affect my emissions, at least until 2009 when I'm exempt.
TLCA # 11402
97 FZJ80
TUTotals
I would do her.
Old 02-12-07, 04:01 PM   #7
dizzidave's Avatar
You will fail
99% sure. I failed when my pulse valve was not pulsing which is associated with that tube. You have to replace the tube if replacing the pulse valve as a clogged tube will bust your new pulse valve. Downey makes a header that works with that. I failed emissions until I replaced oxygen sensor, air pump, EACV and pulse valve (plus pulse valve pipe tube)
83 toyota 22r
dizzidave is offline   Reply With Quote
Old 02-12-07, 04:59 PM   #8
yep thorley does make a header that hooks up to this tube, and the o2 sensor...
toyotaman22r is offline   Reply With Quote
Old 02-12-07, 08:55 PM   #9
Curran's Avatar
LC Engineering also makes a header that has provisions for the "secondary air injection manifold." Just got mine in the mail. Should go on this weekend!
TLCA # 14832
97 FZJ80, 6" Lift, Slee Armor, 35" TrXus, 12k Warn, Milford...
90 Xtracab 4x4
Curran is offline   Reply With Quote
Old 02-12-07, 10:03 PM   #10
valentine's Avatar
I will most likely look into this at a later date.
It's my work rig, so down time is a no-no right now and I can't afford to run into any unseen problems.
It runs good right now, and blows through emissions better than any other rig I've owned!..
Thanks for all the replies.
TLCA # 11402
97 FZJ80
TUTotals
I would do her.
Old 02-12-07, 11:33 PM   #11
"N8"'s Avatar
Um... am I crazy for thinking that 15 min. on a drill press might fix your problem?
...anyone???
-Nate
88 PU long bed, pro comp 33's
All Pro rear suspension
Toyota factory e-locker
4/88's
And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck)
"N8" is offline   Reply With Quote
Old 02-13-07, 07:01 PM   #12
WristPin's Avatar
...anyone???
Youre CRAZY!
Wristy
Jebus...
WristPin is online now   Reply With Quote
Old 02-13-07, 09:44 PM   #13
No longer pre-approved...
2ndGenToyotaFan's Avatar
I'd say it depends on the design of the headers, it may be an easy fix, or a great way to ruin a good header...... Someone try and let us know.
Free Advertising | Fast Loans | Myspace Generators | Proxy | Loans
