Old 01-31-07, 09:06 PM   #1
dizzidave's Avatar
Vibration with 4 wheel drive engaged
Still new to site with pathetic knowledge of mechanics. At low speeds with 4 wheel drive engaged lots of vibration. Mellows out at higher speeds. Problem with front axle Ujoints? If so how easy or hard of a fix? If not, what is it.
83 Toyota
dizzidave is offline   Reply With Quote
Old 01-31-07, 09:22 PM   #2
No longer pre-approved...
2ndGenToyotaFan's Avatar
Well first off, you should not drive in 4 wheel drive on dry pavement, and definantely not at high speeds, you can break something that way. Just FYI...
How low/high of speeds are we talking about? And with the front hubs unlocked and the transfer case in 2 Hi does the whole problem go away? Get a little better? No change?
If it goes away when in 2wd, it has to be in the drive shaft or axle somewhere.
Try giving your front drive shaft a good shake and see if you have excesive play in it. If that's tight, then the problem probably is in the axle.
Old 01-31-07, 09:41 PM   #3
dizzidave's Avatar
I live in Alaska. Very icy. Need it in 4x4 all the time right now, pavement or not. Just had a driveshaft rebuilt. Now there's no more chirping, but still vibration. Never vibration in 2x4.
Old 01-31-07, 10:29 PM   #4
dizzidave's Avatar
Also lots of grease coming from differential. Loose wheel bearings? Please help someone.
Old 01-31-07, 11:13 PM   #5
Ohhhhhh I see. Where is the "grease" coming from excactly? If it's a slimmy gooey mess coming out of the ends of the axle where the ends turn you probably have worn out inner oil seals and the gear oil is washing the grease out of the birfields. This will cause wear and that can result in bad things.
If it's leaking right from the diff, is the fluid level ok? You could be having ring and pinion issues.....
Old 01-31-07, 11:26 PM   #6
I have an 81 and it used to have that same problem when I bought it. My front differential was no good because the front drive shaft created the problem. It usually starts at the transfercase output -> front drive line (make sure it's in phase, ujoint and double cardin joint are ok) -> Front differential Flange -> Differential -> Birfields -> Bearings. That's how I found out that all the problem started with a loose transfercase flange/bearing and down it went.
freeze is offline   Reply With Quote
Old 02-01-07, 01:57 AM   #7
"N8"'s Avatar
Check this out, and check those bushings in your spindels!
http://forum.ih8mud.com/79-95-toyota-truck-tech/37462-grinding-noise.html
-Nate
88 PU long bed, pro comp 33's
All Pro rear suspension
Toyota factory e-locker
4/88's
And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck)
"N8" is offline   Reply With Quote
Old 02-16-07, 12:53 AM   #8
Tried the "hub's locked all the time" in "H2" thing in my 91 (IFS) but my shafts were't balenced. HUMMM???
tntoyota is offline   Reply With Quote
Old 02-16-07, 12:23 PM   #9
dizzidave's Avatar
what's involved with balancing Shafts?
Old 02-16-07, 03:42 PM   #10
Just that 2MK you just can't run around with you'r hubs locked wait'in for the bad stuff then just pull the tc lever.
I'm not implying this is what you did I merely stated an opinon above and I'm answering you'r rebutle.
01-31-07 09:06 PM
dizzidave " At low speeds with 4 wheel drive engaged lots of vibration. Mellows out at higher speeds".
83 Toyota
This is vague every one speaks often with the wrong context. Many other people have stated this, this way. Only you know what where trying to get from you.
Like this "With my TC in H2 and my hubs locked...."
Lots of people think like this "With the 4wd enguaged....."
What part? SEE! Please don't think I'm a hard #ss, I'm just showing you, I'm not narrowing this to you.
01-31-07 09:41 PM
dizzidave I live in Alaska. Very icy. Need it in 4x4 all the time right now, pavement or not. Just had a driveshaft rebuilt. Now there's no more chirping, but still vibration. Never vibration in 2x4
Define "need it in 4wd all the time right now" and "never a vibration in 2x4"
Hubs locked? Not locked? TransferCase yin? yout?
I have a feeling you are driving with you'r hubs "locked" this causes the shafts and the DS to the front diff to turn, all that stuff is not meant to do this in this particular manor(part time 4wD) 2MN all the front shafts are not balanced and all this stuff is spinning under you'r rig when you drive.
AGAIN this is what I'm hearing this is not an attac on you just IMOW what I'm hearing and thinking.
I LOVE YOU MAN, LOL!!!
Wait,Wait,Wait I just now noticed you'r sighn "83 Toyota"... Disreguard ALL above statements.(slipped by me)
Old 02-16-07, 07:05 PM   #11
What???
Were you refering to IFS then?
Old 02-16-07, 07:34 PM   #12
DID, Wait,Wait,Wait I just now noticed you'r sighn "83 Toyota"... Disreguard ALL above statements.(slipped by me) slip by you?
Also see #8 post
Actually, could still apply here.
Old 02-16-07, 07:42 PM   #13
dizzidave's Avatar
Huh?
Let me rephrase. 83 toyota SFA. I leave hubs locked all the time right now, due to snow and icy conditions. I don't drive 55 mph in with 4 high engaged. I do have it engaged half the time when I need to get out of an icy intersection or what ever. I don't throw it in to 4 high if I see an ice patch, I do however shift out of 4 high when I don't need it or if my speed is increasing. Is that bad? I have a rebuilt drive shaft. There is quite a bit of steering wheel shaking and general vibration especially with 4 high engaged but also in 2 high with locked hubs. No problems with unlocked hubs in 2 wheel drive, so obviously rear is fine. I also have "as 2ndgen said" grease coming out the ends of the axle. Not leaking directly from differential. Cause of vibration? Diagnosis? Thanks!
Old 02-16-07, 08:06 PM   #14
I swear I think he's got an un-balanced frt. drive shaft.
Said while scratching head.
" There is quite a bit of steering wheel shaking and general vibration especially with 4 high engaged but also in 2 high with locked hubs. No problems with unlocked hubs in 2 wheel drive, so obviously rear is fine."
Old 02-17-07, 12:56 AM   #15
So is the shaking there whenever the hubs are locked? Weather the T-case is in 2H or 4H?
The ooze coming out of your axle ends means the inner oil seals are shot and it's time to rebuild the axle. It's a messy job but parts are only in the $100-$130 range I think. That's not for anything in the diff though.
Along with the ooze comes increased wear on your birfields and tha could be a cause of the vibration. Another cause could be worn out brass bushings in the hubs, there was a thread here about that a little while ago, I think it was about the IFS front hubs, but the solid axle may have a similar bushing.
Here's a good write up on the rebuild:
http://www.birfield.com/~morgan/tech/axle/
Old 02-17-07, 12:58 AM   #16
You could drop the front drive shaft, leave the hubs locked, and take it for a spin, if it's still there it's in the axle. But if you ahve a rebuilt drive shaft, it's most likely in the axle anyway.
Old 02-17-07, 02:57 PM   #17
dizzidave's Avatar
Alright, thanks guys
Old 02-17-07, 04:00 PM   #18
Yota Tony's Avatar
I'm gonna say the front drive shaft too.
Yota Tony is offline   Reply With Quote
Web Advertising | Electricity Suppliers | Read Techmeme News | Remortgages | Loans
