Old 01-09-07, 09:22 PM   #1
Red face 87 4runner turbo needs help
Hello everyone, my 4runner has stopped working and i have had two mechanics work on it and they cant figure it out. my 4runner turbo was working great i parked and a hour later i went to start it and thats when the night mare began. We have conluded that there is no signal to the injectors so the injectors are not spitting out gas. If i hook up a bottle of starting fluid it will start until it burns it out. i have changed out the main relay , injectors, injectors resistor box and i checked the fuel pump and is working . But thats my problem there is no signal , i took my computer and put it in a toyota pick up 22R and it started up. Please if u know something , anything please let me know .
2fleamarket is offline   Reply With Quote
Old 01-10-07, 03:55 AM   #2
"N8"'s Avatar
stupid thing but check your efi fuse (bottom left on the box under driver side kick plate)
-Nate
88 PU long bed, pro comp 33's
All Pro rear suspension
Toyota factory e-locker
4/88's
And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck)
"N8" is offline   Reply With Quote
Old 01-10-07, 08:59 AM   #3
KLF
KLF's Avatar
Have you checked the ECU for any stored codes? Might not be accurate now, since you pulled the ECU out and put it in another vehicle.
When is the last time you changed the fuel filter?
If you crack the fitting at the cold start injector and jumper the Fp and +B contacts in the diagnostic connector, then turn the key to ON, fuel should spit out. Just making sure you have fuel pressure.
KB1OSF
'98 Lexus ES300
'04 Toyota Highlander
KLF is online now   Reply With Quote
Credit Card Consolidation | Cell Phones | Bad Credit Mortgages | Personal Finance | New Hampshire Flags
