Old 12-15-06, 11:45 AM   #1
3 broken rings, 1 piston and spun bearings - Options?
I picked up that 1980 Pickup a few days ago (got it for what i thought was a good price, way lower than what he wanted), it has a 10" lift, 35" BFG MTs, lockers, 35k on a rebuilt motor, and a few other things...
Two hours later we're driving down the highway doing 65 and I notice that I can't see shit behind us, it's 100% smoke... we pull over and...
Sweet. Have it towed home and we start ripping shit apart.
Turns out it was the gasket at the front of the crank, cheap fix - right? Oh wait, no. I start it up and drives it around the massive dirt lot beside my house and it starts rod knocking/spun bearing noise like ***k so..... shit. We pull the oil pan because I assume it's a spun bearing
Oh, cool. God damn bearing shit, ring, and piston. Rebuilt engine 36k miles ago?
Wtf. Looks like cyl 1 rings (at the least) are screwed. Time to tear it apart.
Valve cover off, cam looks scarred pretty badly.
Pulling the intake mani off, someone ported the head. It has a 22r block with a 20r head.
Head off. Well, that doesn't look good. Where is the ring?
Bearing is eaten.
Fucking awesome. Yes, that's a hole in the piston. Oh, and the pistons are from 93 - according to the markings cast. 36k miles since 93. What the christ?
Bearings for piston number 4. Raped.
At this point we quit for the night since it's was 2am... So where do we go from here? Rebuild the engine, throw a ford/chevy small block in it, get a dead stock Pickup and swap the suspension/other minor things, or what? Money is a pretty big concern so a new shortblock is well out of the question. I assume that this block will now need machining, along with probably a slight overbore which I guess will get expensive.
BFGTAKO is offline   Reply With Quote
Old 12-15-06, 12:08 PM   #2
"N8"'s Avatar
Dude by far your easyest and cheapest fix for this is to buy a parts truck and swap the engine. I just picked up our last one for 350$ way less than your gonna spend on a 350 swap. and if you dont mind when you do the swap changing the wiring harness aswell you could get a FI engine for those steep inclines. I think a rebuild gasket kit is like 80$ for a 22re.
cheap fast easy...
my .02
-Nate
88 PU long bed, pro comp 33's
All Pro rear suspension
Toyota factory e-locker
4/88's
And a whole lot of dents contributed solely by new england's natural flora and fauna (mostly responsible is one species of flora... pine) (and the elusive new england delivery truck)
"N8" is offline   Reply With Quote
Old 12-15-06, 12:13 PM   #3
Yea, I was thinking of doing that. I just have to make sure that the engine in the truck that i buy is in good shape so that i dont get screwed for a 2nd time. Where did you get your parts truck from?
I was also thinking about buying a completely stock truck with a good engine and then swapping over the parts from this truck that are actually good. It appears that everything on the truck, including the body, is in worse shape than i originally thought; which is why I thought of swapping stuff onto a stock truck.
Old 12-15-06, 03:34 PM   #4
KliersLC's Avatar
What did the seller say??
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition
01 Sequoia Limited
02 Camry--Poor replacement for an 80
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Old 12-15-06, 04:19 PM   #5
Velocity2's Avatar
I love my Mini truck and the 22 series engine. Rebuild and run without fear buddy!
1978 FJ40-Sold and Missed.
1985 Hliux. Lock-right in back, Pro-comp XT's 35" and Pro-Comp 6" lift and "redneck extraordinare" P.O.
Velocity2 is offline   Reply With Quote
Old 12-15-06, 04:32 PM   #6
I didnt say anything to the seller, there is no point...i mean there is nothing that can be done about this now hes just gonna bull shit me and piss me off even more...
I was thinking of rebuilding or buying like a crate motor idk which would be better
Old 12-15-06, 06:20 PM   #7
bkg
If I remember correctly, the 93 stamp refers to bore in mm, not date. I could be wrong.
Brian K. Gallus
bkg is offline   Reply With Quote
Old 12-15-06, 06:36 PM   #8
It says DEC 93....
Old 12-16-06, 01:18 AM   #9
Anyone know a good place to get a longblock from?
Old 12-16-06, 01:27 AM   #10
Old 12-16-06, 09:29 AM   #11
85 SA Toy's Avatar
You can check Jasper Engines..... they have good remans....
85 SA Toy is offline   Reply With Quote
Old 12-16-06, 02:29 PM   #12
KliersLC's Avatar
Kragen sells a decent long block....
01 Sequoia Limited
Old 12-17-06, 12:59 AM   #13
"N8"'s Avatar
Go long block if you have the cash. heres a link for DOA's page: http://www.doaracingengines.com/index.html But if not just get a parts truck outa the local classifieds, bring a compression tester when you go to look at it and check fluid levels and gaskets for leaks, and take a look at all the spark plugs. Thatll make sure you get a good engine. there is a good section in any hayns or chiltons manual about diagnosing the combustion of the engine by looking at the plugs.
-Nate
4/88's
Old 12-17-06, 09:14 PM   #14
ajfriz's Avatar
I agree with n8. Even if you need to do a top end, it will be a lot cheaper than a longblock and should give you a lot of trouble free miles. There is also a place that one of my friends brother that bought a complete 22r with a lifetime warranty for $800. They cammed it the way he wanted it. I don't know what the quality was as far as new parts, but he claims it runs well. I will get the company name from him if you are interested.
ajfriz is online now   Reply With Quote
Old 12-18-06, 12:38 AM   #15
Sorry it takes me so long to reply, I was working on the truck all day yesterday and today; just stopped now. Since I can't drive it I decided to fix everything that I don't like on it and redo everything. We bobbed the back end today...cut it right after the rear shackles. I am going to build a some time of flat bed with a spare tire mount a tool box and perhaps a fuel cell. I also pulled about 150 feet of unnecessary wire out (the guy ghetto rigged the whole truck) and we started fixing the body. The body had ripples on the side and roof because it was, apparently, flopped so we push out/in a lot of it and then use bondo to make it smooth. I plan to paint it this week or by the end of next weekend.
It would be great if you could get the name of the company for me. I am still not sure what I am going to do...I was even thinking of doing a 350 swap but that means I have to wait awhile to get all that money together..not sure yet. Thanks for the help
Old 12-18-06, 01:34 PM   #16
Tools R Us's Avatar
If the block and head are good, I would rebuild it. Have heard good things about these guys and the prices are good.
http://www.engnbldr.com/ToyotaHotLicks.htm
Copper State Cruisers #007
Old 12-19-06, 12:55 AM   #17
Well I would probably have to get the block machined and all so there would probably be more value in getting a new engine as opposed to rebuilding...idk
Old 12-22-06, 01:42 AM   #18
Ok. I have decided that I am not going to rebuild the engine. I am thinking about a 350 swap which means that I can sell all of the engine components that I have now which would include the following: Weber Carb, 22r Block, 20r ported and polished head, intake manifold, headman headers, flowmaster exhaust, 4 speed manual tranny and anything else that I won't need for a 350 swap. How much do you think I could sell this stuff for?
Old 12-22-06, 01:57 AM   #19
No longer pre-approved...
2ndGenToyotaFan's Avatar
I'll give you a buck...... you pay shipping.....
Maybe $500 or whatever the market will bear..... But what do I know?
Old 12-22-06, 03:47 PM   #20
85 SA Toy's Avatar
pm' ed you!
Old 12-23-06, 11:16 PM   #21
stick a 4bt cummins in it, gobbs of torque and capable of some nice hp. run a 5 spd dodge tranny and a np 205. i think im just trying to convince myself to do the same.
cummins fanatic is offline   Reply With Quote
Old 12-24-06, 01:41 AM   #22
I wonder how hard that would be...
Idk how it would like up or even if it would fit...any idea? I'll have to search on Toyotadiesel.com and see how many people have done it. I would prefer a diesel actually. I just think that it would cost a lot more money and be quite a bit harder.
Old 12-24-06, 09:44 AM   #23
you can rebuild the 22r with all the nessasary machining for about 650 bucks that all parts and machine work. i would go that route. you must not know what all a 350 is gonna tear up on a mini truck.
offroadr1 is offline   Reply With Quote
Old 12-24-06, 04:18 PM   #24
I thought it was a lot more expensive than 650 to do a rebuild..hmn. I thought that the 350 was fine in there. Are you referring to it breaking axle shafts and stuff?
Old 12-25-06, 06:13 PM   #25
i found a 22r with 85k miles on it, it comes with the 5 speed tranny and the transfer case. How much do you think its worth...he is looking for 1200 but he said its negotiable. Especially if i buy some other parts...additionally im looking for an ifs steering box, wider rear axle, another stock fuel tank, and a few other parts. He said we could do a package deal. I'm just not sure how much its all worth...
Old 01-03-07, 06:50 PM   #26
I bought a whole running but rusted 87 4x4 p'up for $150 a few years ago. Was my 1st Toy now I have parts from that truck on my other 3 Toyotas and still have a complete spare drivetrain and many other parts. Price sounds high. My winter diver is an 89 4x4 p'up that I drive 500 miles a week. Paid $600 for complete running truck to same guy I had bought the 87 from. I am waiting for him to sell me his Ext cab cheap. Those reg cab models are just way too small.
BOGDOG is offline   Reply With Quote
Old 01-03-07, 09:50 PM   #27
ajfriz's Avatar
1200 def. sounds high. I only paid 1500 for my 4runner with a new engine (all paperwork to make sure) and it is awesome. I would look around on craigslist and local ads. I still haven't heard where my brother's brother in law bought his new engine for $800 with a 50,000 mile warranty.
Old 01-04-07, 09:25 AM   #28
Yea, I didn't get that one lol. After looking around I figured out it was quite high. The truck is just sitting in my garage. I put out some wtbs but haven't found much yet. So I've just been modding my evo some more in the mean time lol.
Old 01-06-07, 03:00 PM   #29
Tools R Us's Avatar
You have the best combo for power, 22R block and 20R head, why not just do a good rebuild? www.engnbldr.com has the master engine kit for $219. Take the crank and block to the machine shop, have them measure how much it will need to be machined. Order the kit, have the machine shop bore the block to fit the pistons and turn the crank (if needed) to fit the bearings. Take the head and have them check it also, if you need a cam it's only $88. if bought with the kit.
Probably your least expensive and most reliable option. You will need to tell them the block and head type when ordering the kit to get the correct parts, it can get tricky with the mix and match motors.
Or have you called BAP Imports for a price on a short block? I have an account with them and maybe able to get a few bucks off?
Old 01-07-07, 02:02 AM   #30
I'll check monday but I'm sure I can get you another complete 22r for around $400 if you want it. Otherwise I say rebuild it for a few bucks more. BTW, I'm in east mesa if you ever need a hand, I'm on vacation and have some free time. AND if you do go with the swap, I want that exhaust if it's in good shape.
Looking for another 4x4
Speed_Cult is offline   Reply With Quote
