Old 10-31-06, 08:22 PM   #1
Zack1978's Avatar
Parking brake/brakes locking in reverse
Hey everyone,
It seems that the brakes are sticking on when I try to reverse my 1979 mini 4x4 pick up. I don't know if it is the brakes themselves or the parking brake? When moving forward the truck stops fine, it is just reverse. Any tips on how to fix this problem?
Thanks,
Zack
Zack1978 is online now   Reply With Quote
Old 10-31-06, 09:47 PM   #2
WristPin's Avatar
did you just put on the new shoes?
if you installed the shoes in the wrong place this will cause this.
short shoe goes in front, long shoe goes on back.
Wristy
Jebus...
WristPin is online now   Reply With Quote
Old 11-01-06, 07:06 AM   #3
Zack1978's Avatar
No, nothing has been touched. As far as I know they are the orig brakes that were put on at the factory in 79. Thr truck only has 39,000 miles on it.
Thanks,
Zack
Old 11-01-06, 07:09 AM   #4
IDave's Avatar
TLCA# 13705
Something with your automatic adjuster, I'll wager (provided that year has them), since that's probably what's happening when you reverse. A good cleanup of the parts may take care of it.
9/70 FJ40 +Rollbar
9/64 FJ45 (L) P-B with restored wiring
4/84 Toy 4x4 Mini PU
"The hungry sheep look up, and are not fed: but, swol'n with wind, and the rank mist they draw, rot inwardly and foul contagion spread."--Milton
IDave is online now   Reply With Quote
Old 11-01-06, 02:15 PM   #5
RVBtruck's Avatar
The rear brake shoes will allow forward movement but lock in rev. My gues is that the adjustment is off or the e-brake was used for the first time in a long time and now is frozen on in the cables. Even if the pedal/lever returns they can be stuck. Lift it up in the rear and see if they can be released by grabing the e-brake cable and wiggle the hell out of em. But check the adjustment too.
www.TrannyPerformanceShop.com
.... 80 FJ40 "the toy" buggy 80% done -chevy 5.7 TPI-4 link rear-spring front- custom 700R4-Atlas II-35" race take offs
.... 80 Mini "work truck" 20R-4spd-flat bed- 31.5-aka Zippy (possibly a turbo candidate)
RVBtruck is offline   Reply With Quote
Old 11-01-06, 04:07 PM   #6
KliersLC's Avatar
X2 on the ebrake being stuck/frozen/etc
No problem, I'll just tow the pig to Salt Lake on a UHAUL trailer......
95 T100, beater edition
01 Sequoia Limited
02 Camry--Poor replacement for an 80
"A vehicle's capabilities are inseparably linked to the mental instability of the driver"
KliersLC is offline   Reply With Quote
Old 11-01-06, 05:17 PM   #7
No longer pre-approved...
2ndGenToyotaFan's Avatar
My truck had an unpredictable shake/scary noise and it turned out that the arms from the e-brake cable going into the rear brakes were stuck, and ........ whenever it wanted to it would lock on the rear brakes and freak me out.
Old 11-04-06, 11:41 PM   #8
Had similar problem, cause was leaking wheel cylinder.
ferg is offline   Reply With Quote
Mortgage Calculator | Find a Better Job | Cheap Loan | Go ACC | Short Bowel Syndrome
