22rie
I was wondering if any one knew if there was any way i could add like 20 to 30 whp ? And if so what companies make parts ?
thank you tito |
22rie
In debt to the Shaman
22rie
Cheap things you can do:
Header and 2.25" exhaust. Cam, something like the DOA C270 or TRD#1. I run both, like the DOA. Bored throttle body. Some question as to how much this will give. Plenum conversion (if older than 1988) Expensive things you can do: Port head Balance rotating assembly You can view what I've done at: http://home.comcast.net/~jonmarkstewart/85xcab.htm http://home.comcast.net/~jonmarkstewart/85runner.htm Links for parts and stuff: http://www.doaracingengines.com/ http://www.lcengineering.com/ http://www.engnbldr.com/ |
#4 | |
Anyone else try this or know where a very detailed write-up can be found? It would make great FAQ fodder! Apologies for resurrecting such an old thread but it's the best I could find under search. __________________ 1985 4Runner - ROTM WarDamnEagle's 85 4Runner 1997 FZJ80 - locked and stock 2007 HDJ100 - DD .....and these are just the Toyotas |
Someday I'll go though those old pages and clean them up. I haven't looked at them in years. It is very simple, though I guess I make a lot of assumptions on ones mechanical experience. I guess I could make it a bit more cookbook. Just off the top of my head.
Here in ABQ the throttle body, intake, and cable runs about $60 at the local U-Pull. The job should take less than an hour. __________________ aka Bushrat 1969 FJ40 Project TEROTE: Tim@DOA 3FE stroker (aka 2FE), H55F, SOA/SR, 35" MT/R, 3:1TC ... assembly in process 1985 4Runner: lifted, locked, Tim@DOA 22RE, 4.7 tc, with 33" training wheels. R151F with dual 23-spline TCs in the garage. McCain/Obama - Four more years of hell. |
Like I said, I make assumptions. Gaskets should also be replaced at the plenum and the EGR.
Car Insurance | MPAA | Remortgages | Libro arquitectura | Credit Card Consolidation |
