LinkBack (1) | Thread Tools | Display Modes |
Making a 4Cruiser or Land Runner: 3B diesel swap
I have a 1988 4Runner and a BJ-60 Landcruiser from Canada. After much debating I decided that the 4Runner was just begging for the diesel engine and Landcruiser drivetrain. At first I was thinking of selling the 4Runner and buying a nice clean state side FJ-60, but hell I have had this 4Runner though too many adventures, plus I wanted one ever since they came on the market when I was 5, I remember staring out the car windows at them thinking how cool they were before I ever knew what kinda car it even was.
Has anyone swapped a 3B and Landcruiser drivertrain into a 4Runner, pick-up, or Hilux? I was thinkin of making leaf spring mounts to use the Landcruiser springs and axles as is, rather than modifying the Landcruiser axles to bolt onto the 4Runner. |
I have a bj60 that's really rusty and would love to swap the drivetrain over to a mini truck. the only thing i have heard is make sure you keep all the wiring and gauges from the 60...apparantly that simplifies things a lot? i would love some more information as well
thanks __________________ 72 FJ40 Aluminum Tub 4 Wheel disk PTO Winch |
Measure the hieghts of both engines, should fit pretty easy tho.
I have often thought about this swap also and if you wanted to retain the tcase off the cruiser you will have to use the cruisers offset axle. Or spend a bit of cash and stick on marlins crawler case and mate up the mini truck tcase off the back? Ideas, lets keep em going...... __________________ Come and visit us in Duncan, BC www.raddcruisers.ca --> 60 Series Cable Lockers available - 4.11s or 3.70s - handles and cables included --> 12HT & H55F combos available - complete & running --> in stock and ready to go. |
i think weight might be a problem? Or is that the reason you are thinking of using the LC axls.
lunyou __________________ Myspace - add me if you like 1968 FJ-40 - 4.3 Chevy V6 and 3 spd*PICS ADDED(JUNE 01, 2008) 1985 FJ-60 - SOLD 1986 FJ-60 - SOLD |
what about just swapping the body over to the LC frame/
just an idea not sure how it would work though. |
3B is a 4-cyl, correct? You planning on swapping the axles, too? You'll have to out-board the spring hangers up front a bit, do all of the engineering to move all of the components over, fuel system (sender, etc), fuel lines, etc.
Can it be done? Sure. Easy? Nope. __________________ Brian K. Gallus |
This guide might help you. It is pretty detailed, including part numbers needed for a converting 4 cyl gasoline trucks to 4 cyl diesels.
http://vpizza.org/~jmeehan/toyotadiesel/ |
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/115243-making-4cruiser-land-runner-3b-diesel-swap.html
| Outer Limits 4x4 Board :: View topic - 3B in 89 surf ? | This thread | Refback | 12-30-07 09:11 PM | |
Debt Consolidation | eHarmony Promotional Code | Credit Card | Loans | Mobile Phones |
