adrift in a sea of meh
4runner lifts?
so i got my friend to get ths nice 94 4runner and now he wants it lifted and i cant find a kit that will do a 94(at least on paper) all seem to be for 96-present /or type 1
i dont know anything about 4runners would like a 2-3 inch. any help or links would be much appreciated thanks
__________________ "there is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance- that prinicple is contempt prior to investigation" h. s. another convert to the church of latterday swank, a subcult of Shahrislam |
No longer pre-approved...
Body or suspension?
4Crawler.com probably has a body lift for it. and I know i've seen helper springs in the toyota performance catalog..... HTH __________________ Jerod Online Toyota Parts Catalog!!! 89 4Runner "The James Caird" 01 4Runner, for my Jefferson State Cruisers |
suspension
thanks for the tips __________________ "there is a principle which is a bar against all information, which is proof against all arguments and which cannot fail to keep a man in everlasting ignorance- that prinicple is contempt prior to investigation" h. s. another convert to the church of latterday swank, a subcult of Shahrislam |
Yeah, don't bother w/ a trailmaster/procomp dif drop kit. Go to 4crawler.com (Roger Brown's page) and go w/ ball joint spacers in the front and stock 80 series coils in the rear.
__________________ '73 Datsun PL510 2 Door Saloon '97 FZJ 80 Locked Mall Cruiser. |
http://www.trailmastersuspension.com...oyotachart.htm
scroll to the bottom to view the availible lift for this. I run trail master lifts on both of my trucks. the spindle bracket is lengthened. the use of ball joint spacers is lame. sorry cap'n. alignment specs for camber get tweeked. the rear uses coil spacers, and a panrod bracket. You could use the 80 springs like cap'n says, but either way you need to compensate with drop brackets. 86-89 uses leafs in the rear.90-95 uses rear coil springs. the front ends are the same on all of em. |
Plenty of kits available for this truck - PLENTY! I don't think you searched too well.
I've installed a Rancho (front only) and a Superlift 4". I'd go Superlift any day of the week as choice #1 for the IFS kits. Perfect for 33-35" tires. __________________ Brian K. Gallus |
#7 | |
I had the TrailMaster kit on my 4runner. Unless it's a mall rig only, it sucks. Way too much leverage on the factory lower control arm mounts, poor fit up, the rear coil kit introduces too much travel and height for the factory panhard brackets. I destroyed both lower panhard mounts and cracked the rear axle housing at one of the mount weld areas.
It's a POS. Quote:
thanks for the great info guys
got some LC 80 coils for the rear of a 4runner with Bilstein 5150's stud conversions & panhard drop.... everything needed for the rear except for a brake line for 5.5" of rear lift
$200 for all..... Matt __________________ 94 4Runner SR5 V6 **SASed** 3Link w/Coilovers Pirate4x4 Build Thread 03 Tundra Tow Rig/DD |
#10 |
I strongly second the 1-1/2" ball joint spacers with ultra low profile upper arm stops from Downey. You can get a full 2" or a little more by turning up the stock torsion bars. The weight of the 4runner will allow for flex even with the bars cranked. You can look at OME rear springs or Downey HD coils to match. The LC are great and cheap but may get you a little high depending on which set you use, look for a set off a LX450 to match a ball joint spacer front lift.
#11 |
I'd say you need to take a look over at http://www.yotatech.com/forumdisplay.php?f=60
They have tons of info about 4runners __________________ Allen- "You'll have to speak up, I'm wearing a towel..." Voodoo Blue FJ Cruiser Expedition One Front Bumper Total Chaos UCA's Bodymount chop OME 886/896 AR Chambers 305/70R17 MTR's TRD CAI TRD Exhaust Return With Honor |
#12 |
What he said ^
#13 |
all pro off road makes some nice stuff for the rear suspension on 4 runners check them out at www.allprooffroad.com. i have a 95 4runner i plan to do some suspension work to but for now i took the cheap way out and put on a 3"
body lift to fit my 33's. lots of options for suspension though just do some research you wil find lots of stuff __________________ -Mark pictures __________________ PA TTORA vice president http://www.Pa-tacomas.com 86 toyota truggy 3.0 v6 6" sas lift 35" MTR's 5.29's,locked rear |
#14 |
I run a ProComp 4"
$runners are mostly swappable from 90-95, so if you look in the 4 Wheel parts catalog under the pro comp lift area, yopu can find a 4" lift for IFS with Coil rear. I have been quite happy with it, my truck is pretty flexy for an IFS, and I have done some trimming to gain the ability to run 36" swampers with minimal rub.
__________________ NOt quite an iron pig, but on it's way...
#15 |
I am running bj spacers and cruiser coils on my runner. Works out great, I have a little rake to it and levels out nice when loaded with camping gear and towing my little trailer. Def. need the panhard drop bracket from 4crawler. Here is the info on what I am running
http://www.yotatech.com/showthread.p...935#post961935 It also is way cheaper than any of the good drop bracket lifts, plus you get the added droop from the bj spacers. __________________ -Chris 89 Toy 4wd Van 5spd '93 4runner 3.SLO Auto 4x4 '07 Tacoma Dcab TRD 4.0 M416 |
Car Credit | Mortgage Calculator | Fast Loans | Credit Report | Student Credit Cards |
