Old 07-23-06, 08:56 PM   #1 (permalink)
hilux surf intermitent throttle problem
Hi, i'm having an intermitent throttle problem. When it occurs I shift to neutral and apply full throttle, the engine can't even reach 2000rpm, the revs are consistant each time. I have recently had the fuel pump serviced, although i don't think the electronic components were replaced. Also removed fuel tank and cleaned, replaced all rubber fuel lines, this should rule out any fuel supply problems. I believe this problem is electrical, because if it were fuel suction problems the engine revs would drop slowly as it starved of fuel and it would idle rough after extented periods of full throttle, mine idles fine and under full throttle is consistantly approx 1900rpm. Has anyone had similar problems. Can anyone tell me what the electronic contollers are inside the pump what they do and also any other electronic items that may affect this and their functions. Thanks
Maximum Overdrive Auto Importers
JDM Vehicle Importer & Dealer
BC Dealer License 30432
3411 No 3 Road, Richmond, BC
mdrive is offline   Reply With Quote
Old 07-23-06, 09:21 PM   #2 (permalink)
Is this an auto or standard? If auto perhaps it has a built-in limitation on rpms in neutral?
"If you're going through hell, keep going." W.S.C.
Previa Diesel is offline   Reply With Quote
Old 07-23-06, 11:09 PM   #3 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Are you trying to race it? hehe
Have you checked the TPS and air flow meter?
Also, what Surf are we talking about, year, engine, tranny...
Old 07-23-06, 11:49 PM   #4 (permalink)
WristPin's Avatar
the AFM closes the circut for the fuel pump.
if you actuate that flap in there, the pump should kick on.
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
