Old 07-21-06, 06:29 PM   #1 (permalink)
real time New Alt still no charge
89 22RE pick up 4x4 5spd
Replaced alternator and still no charge. Will start and run on battery.
Checked the two fuses I that the owners manual said are in the charging circuit.
Real time help please! need to get ol' Bessie running.
Apppreciate any advice on things to check.
toyberger is offline   Reply With Quote
Old 07-21-06, 07:51 PM
toynado
This message has been deleted by toynado.
Old 07-21-06, 08:55 PM   #2 (permalink)
original? crapped out about 9 months ago.
replaced it with one from Advance Auto and that worked fine until a week ago. Driving on highway turned on the lights and they started to go dim. Got off and it died completely. no juice left at all.
Figured it was the same problem again, charged batt. drove to Advance, their test showed no charge coming from alt, so replaced under warranty. put new one in and still nothing.
Old 07-21-06, 09:16 PM
toynado
Old 07-22-06, 02:19 PM   #3 (permalink)
Replaced batt terminals, + was pretty corroded inside.
Seems to be charging now- measures 14.5 V across the terminals when running and only 12.5 when not.
Thanks for the help.
Old 07-24-06, 11:51 AM   #4 (permalink)
Jukelemon's Avatar
Make sure your ground strap is good too. You have to have a good ground in a 12v system or nothing works as it should.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 07-24-06, 12:12 PM   #5 (permalink)
Silicon 70's Avatar
TLCA# coming soon
This is true,
Return that Alt.
1996 FZJ80 stock and unlocked "GREEN MONSTER"
1970 FJ40 1f & 4spd "BRUISER"
2001 Highlander "CREAMPUFF"
Silicon 70 is online now   Reply With Quote
