LinkBack (6) Thread Tools Display Modes
Old 07-21-06, 04:21 PM   6 links from elsewhere to this Post. Click to view. #1 (permalink)
Ih8mud stalker
mabrodis's Avatar
Fuel rail pressure when starting? Real Time Help please...
Regrading this thread: http://forum.ih8mud.com/95-gen-toyota-trucks/99905-96-4runner-hard-start-when-engine-warm-hot-long-detailed.html
1996 4Runner, 3.4L V6
Long issue about not starting when warm, can someone, anyone verify what fuel rail pressure they get when cranking the engine, either by disconnecting the coil packs so it won't start or by just kicking the starter a few times so it'll spin but not quite start.
We get 21psi, and am just about ready to go buy a fuel pump...but would GREATLY appreciate any firsthand pressure values...I think any vehicle with the 3.4L V6 would give us valid numbers...
Can anyone check/remember fuel rail pressures?
Thanks a ton!
Mark
"The pessimist complains about the wind; the optimist expects it to change; the realist adjusts the sails." -William Arthur Ward
'96 4runner, 3.4L, 5sp, E-locker, 242K miles
'85 Mini, 2nd owner...add-ons: 31" MTRs, oil & dirt stains, 190K miles
'00 Echo, 255K miles, 1.5L of FURY!
mabrodis is offline   Reply With Quote
Old 07-21-06, 04:48 PM
toynado
This message has been deleted by toynado.
Old 07-21-06, 07:35 PM   #2 (permalink)
Ih8mud stalker
mabrodis's Avatar
Originally Posted by toynado
i think that if u got any fuel pressure it should fire
21 sounds like plenty to me
Ok...thanks for the response...normal idling pressure is 32-36 and it's sposeto hit I think 42psi with the pressure regulator disconnected...we haven't seen that though...got a bunch of parts to replace now...
Thanks,
Mark
Old 07-21-06, 07:45 PM
toynado
Old 07-21-06, 07:47 PM
toynado
Old 07-21-06, 09:46 PM   #3 (permalink)
Ih8mud stalker
mabrodis's Avatar
Hey thanks for the tips toynado!
Just finishing replacing the fuel rail pressure regulator.
While working on it earlier we thought about the wet plugs, but never saw anything wet, all cylinders getting spark (pulled all and had all plugs out while spinning the engine to watch spark).
The starved/flooded question is a very good one, I think it's starved (when this happens, this only happens when engine hot and has sat for ~20 minutes), when cranking it the engine sputters and wants to start.
It sounds like like a vapor lock situation, but ofcourse with a properly functioning fuel injected system vapor lock isn't sposeto happen, unless the pressure isn't high enough...(i.e. pressure regulator isn't working, which is what we're replacing right now).
Putting the meter on the 12v wire at the pump is a good idea, although I don't think we can easily get to the pump, since I think to even get to the wires (other than find them in the wiring harness at a better location) you might have to drop the tank. We have a fuel pump here so if this doesn't fix it we'll drop the tank and go that route.
Thanks for the help!
Old 07-24-06, 11:31 AM   #4 (permalink)
Jukelemon's Avatar
Do you need that ECT sensor?
By the way, I did that trick with the fuel pump jumper wires, completely took care of my issue.
Here is your answer to your spec question.
http://personal.utulsa.edu/~nathan-b...87fuelpump.pdf
Your starting psi's, if your measurements are accurate, are 50% of what it should be regardless of being hot or cold. With the pressure regulator hose disconnected, you should see 38-44psi's at idle. 33-37 at idle with the regulator hooked into the system.
So, that would explain your issue I think. Now what is causing that is a different story BUT the FSM should walk you through it AND that link has the entire FSM on it for both the 22re and the v6. I believe it is the same link as what is in the Facts section.
"May you be in heaven a half an hour before the devil knows you're dead"
1992 4x4 PU
Jukelemon is offline   Reply With Quote
Old 07-24-06, 11:41 AM   #5 (permalink)
CJF
And???
CJF is offline   Reply With Quote
Old 07-25-06, 12:08 AM   #6 (permalink)
Ih8mud stalker
mabrodis's Avatar
Originally Posted by CJF
And???
And...nothing...no change at all...we started replacing the fuel pump tonight...are in Silverton, CO in a campground, actually in my tent right now on a free wifi...kinda sweet, and it's raining...
But no, it's not the FPR, we think fuel pump and wiring to it, since the actually electrical connector into the fuel pump was badly burned...yes burned/charred and falling apart, we we're splicing in new wires, etc...and we'll see tomorrow how it goes...my guess that fixes everything...
Also I found out from Gadget online (dude that is THE source for supercharger stuff on the 3.4L engine) that Toyota's documents are all wrong about fuel pressure, and it should always, ALWAYS be at 43.5psi, and he's seen dozens of trucks, so I tend to believe him...also he said the disconnecting of the vacuum to the FPR is a bunch of crap, that never does anything on any vehicle, ever (his words, not mine)...
Will post again...
Old 07-25-06, 12:20 AM   #7 (permalink)
CJF
Damn!
Watch out for lightning!
Good luck,
Curtis
Old 07-25-06, 10:20 PM   #8 (permalink)
Ih8mud stalker
mabrodis's Avatar
Wahoo!!!
After many hours of back breaking work (we are doing this in a campground remember), we got the new fuel pump in with the spliced in wires and all that...and started it up and not only did it start, the fuel gauge we put on the fuel rail showed 42-43psi, it has NEVER shown that high when running. It would appear all symptoms are gone and it was either (or both) the wiring to the fuel pump (forsure) or the pump was drawing too much current and caused the wiring problem, but in either case, it appears to all be fixed...
We did notice another odd thing today, the pressure quickly jumps to 42psi when you crank the engine, which is great, but as soon as you shut it off it immediately drops to zero. Which is actually not right, and it did not do that before (it was at a lower pressure but would hold it for quite some time, and would actually climb to about 40psi with the gas expanding and all that)...so that's frustrating and I think the fuel pressure regulator is sposeto hold that pressure (it's not actually the pump holding that pressure is it?), and the FPR is brand new...so we'll look at that later, but doesn't matter alot since it will start up without alot of problems, sometimes have to push the gas pedal down a bit, but always starts. We contemplated leaving the old pump in there since the wiring looked like the problem, but that would have been stupid, even for us after how much work that was to get the tank out...
Mucho Gracias for all the help...and Silverton, CO is a blast.. .
Old 07-26-06, 01:16 AM   #9 (permalink)
WristPin's Avatar
GOOD NEWS!
i am glad to hear this!
woo hoo!
Wristy
Jebus...
I like it when I can go out on the porch buck naked ...unroll it and take a wizz without somebody saying ......look john is alive and well
22RE Tech hotline- check the FAQ
Old 07-26-06, 08:29 PM   #10 (permalink)
Oh nevermind......
2ndGenToyotaFan's Avatar
TLCA# 13872
Right on man!!! I love it when I figure something out and get it fixed. Congrats!
Old 07-28-06, 10:34 PM   #11 (permalink)
Ih8mud stalker
mabrodis's Avatar
Update: The fuel pressure dropping to zero right after shutting it off has ceased. After a few e-mails back and forth to Gadget Online (dude with super knowledge about fuel systems on the 3.4L V6, he installs supercharges on them, etc), he said the pressure is held by a checkvalve on the end of the pump, so if the pressure is not holding (and it's not a injector issue) it's probably that checkvalve. However, after a day of driving the pressure is now holding and the 4runner starts beautifully (i.e. crank it with no gas pedal and it fires right up like it should).
Pressure is solid at 42-43 psi ALL the time.
We have a picture of the burned fuel pump wire that we will post, it makes me a bit uneasy thinking others might have a hot fuel pump wire inside of their fuel tank, not a good place for a hot wire, or something sparking...the annoying part is testing the fuel pump voltage at the tank connector would do no good, since this problem was inside the tank on the short jumper wire from the tank's connector to the actual fuel pump, so you HAD to get in there to see/test that (if you had isolated the pump's pressure you could have verified something was wrong, but still wouldn't have known if it was the pump or the interior wiring until you got in there).
Hopefully this thread will be helpful to someone else sometime...
LinkBack to this Thread: http://forum.ih8mud.com/79-95-toyota-truck-tech/102573-fuel-rail-pressure-when-starting-real-time-help-please.html
Posted By For Type Date
'96 4Runner delayed hot start problem... - TTORA Forum This thread Refback 02-25-08 01:30 PM
3.4L hard to start when sitting for 1-3 hrs - TTORA Forum This thread Refback 02-10-08 01:07 PM
'96 4Runner delayed hot start problem... - TTORA Forum This thread Refback 01-07-08 09:01 AM
3.4L hard to start when sitting for 1-3 hrs - TTORA Forum This thread Refback 01-04-08 07:10 PM
Problems with starting... stuttering - YotaTech Forums This thread Refback 12-18-07 05:14 PM
3.4L hard to start when sitting for 1-3 hrs - TTORA Forum This thread Refback 12-17-07 08:08 AM
