Tow limit for Turbo'd HZJ73
Hi all,
ANybody know if a turbo'd HZJ73 can safely tow a trailer with the following weight description: 4920 lb UVW, 6300 lb GVWR? I'm looking to buy a 25ft Airstream trailer... gotta be able to pull it cross the country - mountains and all. Thanks, Peter |
hummm, my concern would be the 4000 lbs of truck pulling 5000 lbs of trailer.
my recomendation would be less than 3500 lb max rating. i have pulled a 4000 lb cruiser with a 800 lb tent trailer behind a HZJ75 in the past but do not recommend it. the power was barely enough with 4.11s and 35" boots... this is just my recomendation... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
1. Stock with sotck gearing .. ? I thought you need to regear.
2. Brakes .. I thought the most important point it is .. Cruiser have faily good brakes .. but for serius towing no. IMOP my .00005 cents .. |
I wouldn't recommend it. In that situation you want a truck that has lots of power to dish out and won't be working all the time. And, you will just need a bigger truck to keep the trailer in line.
__________________ Louis Check out my youtube videos at: www.youtube.com/lshobie Join the True North Toyota Land Cruiser Club in Ottawa http://landcruisers.ca/ |
Diesel for blood
Im in total agreeance with the others, Any vehicle can easily tow many times its own weight(towed a fully loaded truck with a gross weight of 9000 kgs(20000lbs) with a non turbo HZJ75.
However that was with a rope on flat ground. Towing a trailer that is heavier than the the tow vehicle will quickly become a case of "the tail wagging the dog". Going down hill on a bend you hit a bump,it lifts the rear wheels up and the trailer tries to overtake the truck. A very daunting experience
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
tow car to short i dont think toyota has stamped that big of towing capacity on my rego papers it says 2.7t GVM and i can put 400kg in the back.as for power my 13b-t is stock and i towed a full 1.5t box trailer no drama if i need to go up a big mountain range put into low and go you get orsome control
CreditCards | Loans | Loans | MPAA | Librerias |
