Dobinson vs. OME Coil Springs on a LJ78
Could I get some opinions regarding the difference between Dobinson 45mm Coil Spring and the OME 40mm Coil Spring replacements for a LJ78.
Also, is it necessary to also replace the shocks? The current shocks are 1 month old...and manufactured by Monroe under the name of Gabriel. |
I have no clue about the Dobinsons coil springs but the leaf springs on my FJ62 are as level as the day I installed them in May of 2003 at the 3FE spring bash.
No cruiser lean, no sagging at all. I would definately buy Dobinsons agian. Dunbar __________________ Dunbar TLCA # 14016 1988 FJ62 ~285k miles H55F Dobinsons suspension Hot Rod 3FE 8274 ARB Tomball Texas |
i have a set of dobsin coming next month so i will have a report at that time (BTW, i have 2 extra sets for stock for those that are interested in lifting their LJ)
no news now, sorry cheers __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
Diesel for blood
I remember reading somewhere,probably 4WD Monthly,that Dobinsons designed the coils for the LJ/RJ to be a big improvement over the OEM.
Many in oz saw the suspension as the low point on the Bundeera I think they are a kind of 2 stage set up where the 1st 50 mm of spring compression is relatively soft to iron out the road bumps and after that they become become much firmer to handle loads. It will be interesting to see if yours match those claims Wayne. Anyone have any idea of the price difference between Dobs and OME? __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
What about the shocks?
Is it necessary to replace the shocks when I replace the springs? The current shocks are only 1 month old.
the kit i am going to be running has the new shocks included.
if you have longer springs with original stock length shocks then yes you will need longer shocks. __________________ pulling this info out of my ass so take it with a pound of salt contact me at wayne@crushersrule.com Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today www.CAVI.ca Dealers join the CAVI to protect your rights |
i'm also keen to know how you find these...
i want to lift my LJ70 but am not too keen to put OME in it. Are there any other off the shelf options? anyone with OME that is happy with them? |
#8 | |
She idles just fine
I need a set of Dobinson coils for the '93 (hopefully with a slight lift to accomodate the winch), and a set of leaf springs for the '88 (again, with a lift for the winch I am adding). Anybody know where to direct me to make such a purchase? Keep in mind that I am not in Canada.
__________________ Sparkplugs are Irrelevant. 1976 HJ-45; 1984 BJ-42; 1988 BJ-73; & 1993 KZJ-70 Quote:
try Micheal at westcoast cruisers, he is starting to stock some lifts...
#10 |
Panamaboone - can you please post the part # for your Gabriel / Monroe shocks that fit? Much thanks.
Johnny __________________ 88 LandCruiser HJ61, ARB springs, other bush goodies 87 Hilux LN65 stock 92 Hiace SCL |
#11 | |
Diesel for blood
http://www.185performance.com/zen/in...ain_page=index __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#12 |
CAn you please post those shock numbers? Please?
#13 |
i recently put OMEs on my 78, works like a charm on bumps and ruts. i can even speed over mini ramps on the highway, helped a lot on cornering and handling as well. i dont know about dobinsons, some1 offered me before, but id rather go with OME.
you have to change the springs as well, else you wont feel the difference __________________
#14 |
Great Jake, can you give me an idea of cost for your 78 OME setup - ballpark figure. You scrapped the stock elec shockies then?
Thanks, Johnny __________________ 88 LandCruiser HJ61, ARB springs, other bush goodies 87 Hilux LN65 stock 92 Hiace SCL |
#15 |
OME shocks and change the springs?
Could you tell us a little more about the cost of the OME and changing the springs? I'm thinking of ordering some OME but don't know how much new springs would cost or even a new set of coils on the front since they seem to get the most wear.
#16 |
I as well am in the market for some suspension, for my LJ78. Wayne you had mentioned a while back you might have some stock 80 springs that would fit a LJ78, to help with the rear softness. Wondering if you still have them?
Also a friend of mine wants to upgrade his 2 1/2 '' OME setup to a 5",His vehicle is a 80 series. From what I've heard the springs are interchangable 70/80, how are the shocks? I'm asking this in regards to "trying" to install his lift on my LJ78. Or maybe the better (simpler/cheaper) route is to put on a set of rear stockers(80 series), being on a budget. Thanks - As for OME VS Dobinson, my friend there saw a mojor inprovement from stock with his 2 1/2 '' OME setup. |
#17 |
I did a approximate check on the coil diameters and I got a 6'' reading for the rear of the Lj78 and around 4- 4.5" for the front
can anyone confirm that, I have trouble fitting under the LJ |
Mortgage | Advertising | Mortgage Calculator | Remortgages | Credit Cards |
