Yep, I'm making my Turbo Diesel/gas Troopy an automatic.
My manual trans has nearly carked it with very notchy 2nd & 3rd sychros, I drive in traffic quite a bit, have a dodgy clutch foot and when I drive off road its quite often in heavy sand. So it seemed like a good opportunity for a project
I'm putting a hydraulic A440F out of an early 80 series in it.
Then adding a Nomad Valve body http://www.automatictransmission.com.au/release.asp?NewsId=4651
Then coupling it to their billet, low stall, lockup torque convertor http://www.automatictransmission.com.au/release.asp?NewsId=41077
Cooling it with one of these
http://www.ebay.com.au/itm/Dual-Pas...=AU_Car_Parts_Accessories&hash=item1e863bb885
I'll still need to shorten/lengthen the drive shafts, change the bellhousing, modify the flexplate, as well as fabricate a new crossmember to hold it all in place. Electrically it's quite simple, just the neutral position switch spliced into the ignition wire to the starter, fit a Transmission oil temp gauge, reverse lights and wire up some relays for the centre diff lock.
Anyway, this'll finally unfold over the next month or so, I'll post some photos for anyone who is interested.
Cheers
Tim
Cheers
Tim
