My troopy caught me off guard and the ignition stuck on me after i put some silicon spray in to free it up. In essense i am guessing the key or lock has worn at different speeds and my putting silicon in made everythign free up rendering the key not working
I looked at getting a new barrel - but no one could guarantee that i would be able to key it alike to the locks -something to do with the later model barrels have a different key?? -either way i decided to rebuild
Steps
1) remove housing around steering column - if you key works intermittentantly great get the ignition to acc -if it helps wiggle the key up and down -this will help shake the pins - if yuor key does not work you will have to drill the pin that faces the steering wheel (you will need to remove the indicator/light stalk housing
Steps
