Got a 93 HZJ75 here at my place for a few things to be gone thru / fixed. Got everything except for the drivers side lowbeam working. The highbeam works just fine. I have no wiring diagram for this truck but have tried to chase wires with no luck. I chased them from the plug at the light back to the firewall and nothing wrong that i could see. I do know it is not the light itself as i have tried numerous lights i had around here, and they all worked on the passenger side.
It has no fuse box cover but i was able to find the 2 fuses for the headlights and both tested fine both in and out of the truck. I can hear the relay coming on under the dash.
I did take the light switch out completely and found a wire just hanging on so i resoldiered it back on hoping that was it but alas, it was not the fix i was looking for.
One last question here.
Where is the body ground normally located at on this thing ? Found / got the one from the battery to the engine, and the starter to the frame, but never found one to the tub itself, so i put one from the battery to the tub, and the wipers run much better now.
Thanks for any / all help.
__________________ Wife said i needed a real job, so i quit the PO and started a hobby.... http://canuckscruisers.com/
ummm, did you test the wire on the light side of the plug to make sure the power is getting completely TO the light itself?
i have seen the small clip inside the plug pushed back far enough that it wasn't making contact but everythign looked normal.
just a suggestion as i suck at electrical
__________________ we are all given sh*t in life, but some of us learn to turn it into fertilizer and grow from it, and some us try to fling it on others like monkeys.
This is my third truck in a row with a wiring issue, wish they would stop for a bit.
Was thinking of trying a new headlight connector. Now wiring under the dash is a mess, but only with PO's wiring stuff, not with the factory wiring.
Wayne, the guy that owns this one wanted me to make a overhead console like the one you did awhile back, but right now i have no way to Tig so he is waiting for a bit.
i have made 3 so far and can make another if need be ...
not cheap
not quick
but it will be done right.
same manual as the HZJ75/PZJ75 ...
The HJ75 had an identical wiring diagram to a HJ60 and apart from things related to the engine it was not changed much on the HZJ75 that Im aware of..
So a 60 series 84-90 body chassis manual should get you going most of the time
__________________ Shoot straight ya bastards and dont make a bloody mess of it.
Breaker Morant at his execution
FJ73+1HZ Diesel NEW GEARBOX. SOLD : (
Holden Commodore V6
Honda XR650L
Triumph Rocket3 08 (with some extra punch)
I seem to remember one from the gearbox/tcase to the chassis,left hand side?
Holden Commodore V6
Honda XR650L
Thanks much, got the one from on here in the online place posted in this forum. Still a bit confused by it but am going try to the easy thing first this morning and replace the one piece where the light actually plugs into.
Thanks, will look there this morning also, but i also think we will keep the one i put on it for good measure.
Thanks again
