so i am getting the left over parts catalogued and put away and i come across some interesting facts:
the flywheel is 2 piece simular to the PZ design
the front and rear driveshafts are exactly the same size
it will be interesting to see how the 2 pc flywheel compares to the PZ in dimensions and design...
cheers
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
when i get a bit more time i want to pull the 4 speed, take the case off and compare with the 5 speed. the cases are identical, the output shafts are identical, the t/case is the same, it seems the counter shaft has to match the gears inside and the imput shaft needs to be swapped over but in a nutshell i think it will be a cake walk (famous last words).
the pilot bearings are the same between the HZJ and the PZJ also...
