05-25-10, 03:36 AM
#6 | | Rookie
| 80 series I have an 80 series and about to do the swivel hubs, your thread is awesome, and cant find the rebuild have you posted it yet?
Is the 1995 80 series the same swivel hub?
you can email me at themonique70s@hotmail.com |
05-25-10, 07:18 AM
#7 | | 250+ Club
| 80 series swivel hubs use a different rebuild kit, but the process of overhauling them should be very similar to the guide SteelArt has posted. The swivel hubs on in this thread are common to all Landcruisers from late 1979 to mid 1990.
Love the thread, I'd like to know what rebuild kits you're using SteelArt? Last lot I bought were a cheaper set while they did the job, I'd like to totally rebuild everything in the FWH to the kingpin bearings in my '84 HJ 47, photos of your kit looks comprehensive and good quality.
__________________ 1980 HJ 45 trayback - sold :(
1983 BJ 42 shorty - rustbucket parts rig
1984 HJ 47 troopy - On the road, selling soon
1981 FJ 45 trayback - new project
1983 HJ 47 trayback - bigger project
2011 VDJ 76 wagon with factory lockers. |
05-26-10, 06:16 AM
#8 | | Forum Regular
| great thread - much appreciated! |
05-28-10, 04:38 PM
#9 | | Burning dinosaur bones...
Join Date: Mar 2008 Location: Sunshine Coast, QLD, Australia
| Thanks for this SteelArt. Very informative thread with all the pics! |
05-29-10, 04:15 AM
#10 | | 250+ Club
__________________ If it seems like a good idea then start cutting ...
Want to know more about Fabrication ? - www.ozf.com.au  |
05-29-10, 07:25 PM
#11 | | 250+ Club
| Excellent way of seperating the CV from the inner axle, I'll remember that one.
06-14-10, 08:40 PM
#12 | | 250+ Club
| I'm in the process of doing this right now on my HJ60 actually. Great reference, thanks for taking the time to do this writeup. |
06-15-10, 02:58 AM
#13 | | 250+ Club
| Vrey good. That is a good display of how to do that job. I onley get 7 hours to do that and reassemble. |
06-15-10, 06:39 AM
#14 | | Club 4X4 Panamá
| big thanks for this thread .. that's the way that you should work .. ( wish I have this space and bench press  )
__________________ HJ-60 2H-TI Tencha
HDJ-80 1HD-TI Marilu
Cruisers on my mind, blood and soul ! Join us at our local Panamá Off Road Forum Quote:
Originally Posted by crushers if you are achieveing the max boost then it isn't the boost that is going to kill your engine... it is your right foot. | |
06-19-10, 02:10 AM
#15 | | Addict
| Huge thanks for a great thread ! |
07-07-10, 02:18 AM
#16 | | Rookie
| Brilliant writeup. But to pick one thing. The steel washer goes on last, that is 'outside' the felt washer on the swivel hub. It is a s.c.r.a.p.e.r. (swear filter?) It should be sprung slightly against the ball and is used to remove buildup of dirt and dust, leaving the felt pad to wipe the remains to protect the rubber seal lip.. The rubber seal is last in the series (from outside in)to retain the grease.
07-12-10, 11:52 PM
#17 | | 250+ Club
| Excellent write up, must have taken awhile to photograph and do.
I always get halfway thru documenting it then give up.
Thanks!
However previous post re seal arrangement.
The seal arrangement in the write up is correct. (Also is in factory manual)
Felt wiper over swivel ball first, then rubber then finally steel washer.
Put on swivel hub.
The steel washer locates into swivel hub and supports the rubber wiper and the felt from falling into the gap between the hub and ball.
Also soaking the felt washer in oil helps slip it over the ball and return to its proper shape when bolted up.
Also acts like a seal.
I was told by an old salt that's what you do with felt seals.
Works for me and I have had mine out several times.
__________________ Calvin Tyler
1994 KZJ78GW Landcruiser Prado 3 in lift, Warn XD9000i, PTO mid mount winch  , factory rear elocker, home made front, rear and side bars.
Auckland, New Zealand
Yeah way down there!
Reason: add pic
09-30-10, 04:37 PM
#18 | | Forum Regular
| This was a great write-up! Thanks SteelArt. I'm ground-up rebuilding my 1985 Aussie-market HJ-75 Troopy, and I used this thread for the dis-assembly of my 299,000 km front axle. It was 100 times better than the Gregory's #502 I bought last time I was Down Under.
Now... Where's the RE-assembly? I tried the rebuild link SteelArt referenced, but I get a 404 error - Not Found. The URL embedded in the text was http://4wdaction.com.au/forum/showthread.php?t=90889.
Can anyone point me to it?
Or another good place for tips rebuilding swivel hubs, setting knuckle preload, etc...?
Thanks!
Darrin in Wyoming |
09-30-10, 06:44 PM
#20 | | Forum Regular
| Quote:
Originally Posted by SimonInAustralia | Spot on, SimonInAustralia. Many thanks. Just received the cone washers for the steering arms tonight, so I'll get after this rebuild tomorrow. Now I gotta pick some grease for the knuckle bearings and CVs. |
