02-26-05, 10:43 AM
Location: Tauranga New Zealand via Vancouver Island Canada
Cheap lift options
Question to 70-series owners. What are the options available to me when considering a mild-medium lift to clear larger tires and gain ground clearance on my stock BJ70?. I have heard of "add-a-leaf" kits, and flipping the axles so the springs are on top. Other than longer brake lines and shocks, what re things that must be considered?
Are there backyard/junkyard options avilable to totally impoverished owners like me?
MOOSE
SOLD HER - SOMEDAY SOON
JDM's...THEY SAVED THE BEST FOR THEMSELVES!!
02-26-05, 11:11 AM
Belton--- relativley cheap and best bang for the buck
Jeep add-a-leaf--- cheap and works great, been running these off and on for years
block and extended shackle--- 3" lift cheap and very flexable, easy to fit 35s.
extended shackles--- cheap and only good for about 1 1/2" lift
terrain tamer--- nice ride, medium expensive decent bang for buck
OME--- $$$$ and made at the same plant as Belton... waste of money
cheers
02-26-05, 11:29 AM
The Parabolics seam pretty reasonable, I think my customer got in on the groupe buy for his lift thats going on the 45 diesel.
I am on the ARB list for the Vancouver Island dealer and can sell the Dakar, sold out at the moment.
But it sounds like you are speaking bottom dollar, so you could see Bob and Mark at Hub City Spring, they could rearch your springs and reinstall. I suspect with your low milage they should be in great shape, not liked the cracked rusted out BC springs.
This fix would be half the price of the Belton or Dakar, so you should weigh the long term issues that will arrise with this fix.
Maybe a set of 1 inch shackle lift also might help.
Rob
Come and visit us in Duncan, Vancouver Island, BC
www.raddcruisers.ca
Monday - Friday 08:00 - 17:00
02-26-05, 10:16 PM
I got in on the parabolic group buy--too bad that Feb. 15th was the deadline. Full set of (what I hear to be) nice riding and excellent flexing springs for ~$600USD. Piecing together shackles, shocks, etc. now...
B
Brendan
1983 BJ42  bioD, lots o' Aqualu, TIC Parabolics/DT8000s, Tuffy, 33x9.5 BFG ATs, SOLD
02-26-05, 10:35 PM
Originally Posted by moose_sv1000s
...and flipping the axles so the springs are on top.
Uhm...that's not a mild-medium lift, Moose.  That's a Spring Over Axle conversion, commonly refered to as an SOA. Mondo lift to clear mondo tires. you have to cut and turn your axles to keep the proper pinion angles, hy-steer, etc. A mild-medium lift is usually a common Spring Under Axle (SUA) lift kit as already mentioned by Crushers and others.
02-26-05, 11:58 PM
Supporting Vendor
Go with the Belton's and be done with it, it is worth the money you will spend. You will not be disappointed IMHO
Michael
02-27-05, 09:24 AM
I haven't ridden in a Belton but from everything everyone says it sounds like the best bang for the buck. I went with a full OME setup (before the dakar came out) Heavy front, med rear and I couldn't be happier with the ride. Plus you know OME has been making these for 7x cruisers for a long time and the R&D that went into the kit. I'm hoping to step up to some 34x10.5 here before moab. A properly done spring over is going to run cost less than a kit but it usually adds up to about the same as a kit by the time you rebuild knuckles, u-joints, trackbar, brake lines, etc
I decided on OME just because I usually expect to have my rigs for a long time and the difference isn't all that great in the long run.
Only kit suspensions I would consider would be OME (regular or dakar) and Belton. I bet some of the other Aussi ones are pretty good too they just don't have any real presence in N/A
Oh.. forgot you said cheap. Do maybe a shackle lift and save up for a kit. Although I really like wayne's little J**P add a lift that he did on Zepp's 40. How much does that add a leaf option run wayne?
1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car
Rising Sun; Former CLCC
You should be able to delete your own thread. Communists abound
Real Change is here --> Cato Institute
02-27-05, 01:20 PM
What you think about this cheap setup :
add one long regular leaf (not thick add-a-leaf like rancho, a "regular" leaf like the other in the pack) in each pack, then rearch the leafs srpings ?
(I here that option for about 250$ CAN if I bring them the leaf.)
BJ42 1982 * The Primitive Beast BJ70 1985 * The Green Machine 1992*Corolla*All-trac* The Quiet Spirit
Si je dois aller en enfer... ce sera en Landcruiser
02-27-05, 07:29 PM
it is $100 for the front and a $100 for the rear... new u/bolts and done...
03-02-05, 02:44 PM
#10 (permalink)
the shackle lift would be simple to put on right now Moose! Then you can save for the beltons. We could fab and install the shackles in a day. No need for brake lines or shocks for 1" lift(2" longer shackles)
no cruiser right now
03-02-05, 04:17 PM
#11 (permalink)
It won't ride very nice with shackle lifts, but it will clear larger tires, is cheap, and will tide you over until a proper lift kit is in the budget.
03-02-05, 05:46 PM
#12 (permalink)
Stoney,
i disagree, the ride is actually better, the handling sucks with just a shackle lift unless correction shims are installed...
03-02-05, 05:50 PM
#13 (permalink)
Originally Posted by crushers
Stoney,
Wayne, Stone and Chet, could you guys elaborate on the shackle lift? I understand they're h-shaped steel weldings, but don't they throw off the caster/camber of the truck?
Any pictures of them in place? What would be the anticipated raise?
MOOSE
03-02-05, 05:56 PM
#14 (permalink)
Hi Wayne: Could you please elaborate why the ride would be better? If you do take the effort to shim and correct everything, my intuition is that you haven't then changed much (ie. springs) aside from longer shackles...so how could the ride be better? I have heard that some rigs that have run large shackle lifts have terrible bump steer and other poor ride qualities. Thanks.
03-02-05, 08:26 PM
#15 (permalink)
Wayne: Thanks for the tips on the add a leaf. Forwarded the info to my friend. Cheers.
03-02-05, 09:04 PM
#16 (permalink)
all a shackle lift is is longer shackles than stock. because your only lifting one end of the spring you only get 1/2 the height of the increase in shackle length.
So going 2" longer shackles will net you 1" of lift. I am not sure what your stock center to center measurment on your shackle is but a length of 3/8" x 2" flat bar and a chop saw and drill press will be pretty cheap!  Funny I have all those! minus the flat bar. You may need new bolts depending on how hard yours are to get out.
As for the shims only the front axle will need them and basically we take a pinion angle measurement stock then after the shackle lift and go to island spring and get steel shims of that angle(make sure you don't use alum ones!)
Let me know if you want me to show you one day what we are talking about.
03-03-05, 10:52 AM
#17 (permalink)
cheers
Belton... where I can I find that product in CANADA. How much $ Is there a Belton web page ?
And for the jeep add-a-leaf : the long or the short one ? is the short one are stiff ? to much stiff ?
03-03-05, 10:57 AM
#18 (permalink)
03-03-05, 11:32 AM
#19 (permalink)
I don't mind shackle lifts to help in the rear but I always disliked them in the front. Esp with a longer shackle that doesn't have a brace in the center. The steering tends to get soft since. JMHO
03-03-05, 04:10 PM
#20 (permalink)
what is the maximum lift that a regular shock (monroe, rancho, OEM) can support.
1" ?
2" ?
3" ?
and when I have to care about changing for longer brake line ?
03-03-05, 08:47 PM
#21 (permalink)
I have had belton on my60 for almost three years, no complaints.
Holding up very well.
81 BJ60 turbo, intercooler and more
06-24-05, 08:49 PM
#22 (permalink)
cheers
Wayne, this is an ancient post that I want to revive briefly.
I am expereincing more "roll" in corners than was apparant 6 months ago, is this a result of sagging springs or spent shocks or both? How could I stiffen the ride and maybe get some height for looks as well?
With the add-a-leaf kit, could you please quote a part # and/or a price if you supply them?
MOOSE
06-24-05, 09:55 PM
#23 (permalink)
Moose, I put the belton on my 61 and love it. The rig came with OEM springs and a shackle lift... handled like CRAP! I like the beltons, and the lift is impressive. I know its not like your rig, but if you want to drive it before committing, no prob
1982 BJ60... Rusty... and not so trusty... RIP - Rust In Peace
1989 HJ61 12H-T
'07 Kawasaki Versys with lots of stuff -DD-
'03 Jetta TDi Wagon -44/55 MPG-
http://www.fuelly.com/sig-metric/29172.png
Steve
06-24-05, 10:34 PM
#24 (permalink)
Belton springs seem to be the affordable way to go. I am just wondering how affordable they are, and if they are available for a HJ47. A buddy of mine quoted me $620 for all four HD OME Dakar springs. Do Beltons run significantly less than this? Do they also produce anti-reverse shackles?
1983 HJ60 GX Sahara
1984 HJ47 Troop Carrier
1973 FJ55 Rusty Wagon
2003 KTM LC4 Adventure 640
06-24-05, 10:45 PM
#25 (permalink)
I can't afford new spring packs right now, so cheapo band-aid solutions until I win the lottery are the order of the day.
MOOSE
06-25-05, 06:04 AM
#26 (permalink)
How much of a lift can you go before you have to change driveshafts etc?
1986 BJ70, 24v with a 3B
06-25-05, 09:48 AM
#27 (permalink)
For me it's not so much lift, rather fix the sag and stop the rolly-polly handling.
BTW, for all you spring experts...how many leaves in a standard BJ70 pack? There are 6 in mine, but the clamp that holds them makes it seem like one leaf is missing?
MOOSE
06-25-05, 04:49 PM
#28 (permalink)
jeep add-a-leaf from Rancho, the lighter lift ones and the ride is great, the flex is great but they will wear out in a couple 3 years...
been running these for years...
cheers
06-25-05, 05:01 PM
#29 (permalink)
cheers
Just YJ leafs? OK. Thoughts on whether I'm missing a leaf already?
06-25-05, 05:06 PM
#30 (permalink)
nope, i would guess not. the extra room is to allow the springs to articulate...
