Looks good, did you paint it? It seems like its grey in those pictures.
I guess Ill see you at the liver quiver again, I may need someone well equipped to tow my mall cruiser around out there! My brown 60 has gone to cruiser heaven.
__________________ 92FJ80 Cummins 6BT w/NV4500, Airbagged, part time 4wd conversion/split case, rancho's, custom bumper+8274, 37" nittos,Mall Ready.
60 series, getting hilux cup holder upgrade presently...
Unless my math is horrible, it doesn't help. I can only see about 75:1 unless you have a non Toyota Transmission or portals
What is expressed as 1.08:1 in High and 3.05:1 in Low is not the final reduction ratio, but it is the ratio of the transfer case gears that were replaced with Marks gears.
cody c Oh No ! The 60 is gone, that is horrible
Yes, liver quiver it is . Looking forward to chumming out .
__________________ 89 BJ74 ARB lockers front and rear , Marks 1.08 to 1 Hi and 3.05 to 1 lo. I am using EMU springs for 2012. 24V 6hp 8274 and a good driver
89 HJ61 cable lockers, 12H-T, H55F ,slowly bringing it back to showroom condition 285, 75 R16s
1942 modified willys mbt 1/4 ton trailer , it float
2009 Aprilia SR 50 Factory R ; Malossi Full Circle crank, Malossi 70cc BBK , VL 14 reeds, continious cruising speed 110km/h
Gone
1980 FJ 40
1990 W-250 cummins ram ( ordered in 89 3rd on the list) sold @ 880,000kms still running today
1990 LJ78 prado 2.5 EMU Lift ARB rear locker , factory winch (stolen)
Gone
1980 FJ 40
How is the difference? I been considering these Marks for years.
Yes your option is as stated.
Hi gotoy
I have had the Marks Gears in my BJ 74 for 4 years now.
Total mileage since Marks gears were installed is 116,000 kms.
(My driving habit) My front hubs are always in the LOCK position
I have a couple of witnesses that can tell you that the transfer case has been in 4wd for 75,000 and 60,000kms for Low Range.
As soon as I am off the pavement 4wd is engaged .For trail use it is ALWAYS IN LOW RANGE or any dirt driving under 25kms per hour.
(NOISE) or very light whine
My BJ 74 is my EXPO/ Off road vehicle. The only time it goes on the pavement is to head to the trail . So at speeds from 65km/h up there is a constant whine, it is not harsh but it is there. I gladly put up with it for its ability to drive slow when needed.
The tranfer case internals are quite abit stronger than the OEM gears.
My 74 is in good shape meaning on a good dirt road @ 90km I can engage and disengage 4WD directly and smoothly providing that the rear wheels are not spinning, sometimes I can engage and disengage @ speed several hundred times a day if I am travelling hundreds of KMs on Gravel/ Hard packed dirt.
In a note; the ability to drive slower outweighs the mild whine tenfold. I usually take about 2-3 months off in the summer to Expo hundreds of Kms away from ciivilization while having to pick up supplies and fuel every 2 weeks( I have a Waeco CF 110 ) and carry up to 60 litres of diesel in gerry cans. Driving slow in low range driving around 10-12 hours aday @ 1200-1600rpms the 13B-T can go along way.
I would like to go a little lowe A couple of the sprung over guys like Lowenbrau and Behemoth 60 have Marlin Cases with 4.7 to 1 low. I hope this helps (it took me along time to type) LOL PS I always take the torque off the case every time I stop on the trail by taking it out of 4wd or putting the case in N
Gone
1980 FJ 40
Anytime AlbertoSD . The Marks gears were used and in the transfer case when I got them. They are holding up quite well.
Gone
1980 FJ 40
The 60's old worn out body is gone, but the drivetrain lives... Its being swapped into a slick little 4 door hilux , but wont be ready for the shiver, though maybe for the beginning of summer.
