Old 10-10-09, 01:54 AM   #1 (permalink)
Hulsty's Avatar
The Silver Bullet - new bar work and stereo
Thought I'd start a build thread for the silver Bullet as its stock at the moment.
Getting it ready for a road worthy tommorow. So this weekend I fitted all new old man emu bushes, and front anti inversion shackles and new rear shocks. Was going to fit greasable pins but the old man emu ones dont fit! The offset 12mm head bolt doesnt line up and the larger diameter alignment part is 46mm instead of the required 51mm bit pissed off.
Also trialed my 35'' Pedes today, unfortunately they hit the exhaust.
Plans are move diff forward about 40mm for clearance. I have some sagged 4'' springs for the front which will be about 2'' with the winch and bar work. And I will fit the rear springs from the Red barron to this which will be about 2'' lift with stock shackles. I will complement this with a 1'' body lift I think for tyre clearance at the front. Sound like a good idea?
Sitting on its own weight
The Red Barron - FJ73 - FOR SALE! Inquire via PM
The Silver Bullet - BJ74
Hulsty is offline   Reply With Quote
Old 10-10-09, 07:29 PM   #2 (permalink)
That look awesome on the 35's, better condition than my newie.
Keep us up to date with how you go with it, i'm about to go through the same process with mine.
benmgsr is offline   Reply With Quote
Old 10-10-09, 07:39 PM   #3 (permalink)
Clint79's Avatar
looks nice and clean
pitty about your exhaust but you know the rules if it hits, chop it off
are you going to remove you oem front flares do you have the ones of you fj ?
J7
Clint79 is offline   Reply With Quote
Old 10-11-09, 10:25 AM   #4 (permalink)
lulo's Avatar
Exclamation
Originally Posted by Hulsty View Post
KILLER!
Great Tires...
LULO Adventure
Land Cruiser LJ-70`88 "El Niño"
A Coruña - España (Spain)
"Eres lo que has viajado"
My Cruiser "El Niño": http://forum.ih8mud.com/70-series-te...o-lj-70-a.html
LULO - Photos: http://www.flickr.com/photos/lulo_adventure/
lulo is offline   Reply With Quote
Old 10-12-09, 04:32 AM   #5 (permalink)
can you please tell me how high it is to the top of the step so i no if im over the 150 mm. Nice straight truck you have there. Thanks
FJ73 is offline   Reply With Quote
Old 10-12-09, 05:07 AM   #6 (permalink)
Hulsty's Avatar
to the top of what step? from where to where?
Sidesteps are now gone.... SOLD! and whats the 150mm thing?
Old 10-12-09, 05:54 AM   #7 (permalink)
To the sill or chaise then please in NSW the max that you can lift is 150mm. Im not shore if mines over it yet its 800 mm to the sill on mine with my 35 i think,
Old 10-24-09, 03:14 AM   #8 (permalink)
Hulsty's Avatar
Sorry mate forgot to measure the car I will when I get a chance if you still need it?
Swapping a few things between cars. And my 3-4'' lift springs behind my 2'' lift springs. I'm hoping the 3-4'' springs are abit sagged and leaves the front just lower than the rear.
Old 10-26-09, 03:59 AM   #9 (permalink)
Yes please i have no idea what the standard hight is thanks.
DRIVE IT LIKE YOU STOLE IT....!
FJ73 39.5" iroks SOA leaf alround with crazy front flex...
Old 10-26-09, 04:45 AM   #10 (permalink)
Hulsty's Avatar
Just measured from the ground to bottom of chassis under the passenger door, 470mm.
Old 10-26-09, 05:11 AM   #11 (permalink)
Hulsty's Avatar
Got the car registered on Friday morning, Fri arvo it went into the garage. Now it is twin locked, widened front diff, 60 rear diff, lifted suspension, boost controller, better drivers seat and 33'' muddies.
Unfortunately the 33'' rubber rubs hard on the front guards when flexed up and I dont know if a 1'' bodylift will be enough with my 35'' tyres. I dont really want to cut into the front guards as it looks so damn good!
I am really pleased with the front shackle angle and approach angle, with the 35''s on the approach angle should be really good. The diff is about 30mm forward at ride height.
Front shocks are maxed out, I need longer ones to take full advantage of the springs.
Rear is nearly at max droop but has more compression left. Setup is working well so far.
Few pics.
Old 10-26-09, 06:23 AM   #12 (permalink)
Clint79's Avatar
looks nice mate
i love the OEM flares
locked and 60 rear diff etc you dont muck around do ya?
J7
Old 10-26-09, 07:34 AM   #13 (permalink)
Gib009's Avatar
Awesome stuff mate! You have done it all before so you know exactly what works and what doesnt. No messing round! Looks like it will be a great hardcore tourer with the 35s
Not putting the arb bar and winch on the new one?
87 Toyota Landcruiser BJ71 on 35's
Gib009 is offline   Reply With Quote
Old 10-26-09, 03:24 PM   #14 (permalink)
Hulsty's Avatar
Jezzz dont put to much pressure on a bloke!! Only so many hours in a day to swap parts over. Bullbar and winch is last major component to be swapped over. Probably this weekend, four day weekend!
Old 10-26-09, 07:46 PM   #15 (permalink)
Thanks mate. Sweet looking midi there such a great truck good luck with it.
Old 10-28-09, 06:32 AM   #16 (permalink)
Stand and deliver
roscoFJ73's Avatar
Looks great Hulsty. Hows the power of the 13BT compare to the old 3F?
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 10-28-09, 03:20 PM   #17 (permalink)
Hulsty's Avatar
Its great, the 3F accelerates better due to the larger rev range. The 13BT holds hills better and has better in gear acceleration. At current i'm running about 8.5-9psi boost and the same diffs/tyres as were in the FJ73. On the way to work up the steep hills in 4th gear the BJ74 drops to 80km/h from 90, the FJ73 dropped to 70.
On lowish speed dirt stuff the BJ74 definitely feels like it has more poke.
Not sure how it will go once in low range with the 35''s on, for some reason the BJ74 doesnt like pulling from low rpm, is rough below about 1100rpm. The FJ73 would go down to about 600rpm and pull away on and offroad where as below 1100rpm in the BJ74 gives driveline vibration and general rough running when taking say a corner in 3rd gear and dropping to 1000rpm.
Have done ~260km to quarter of a tank though!!!
Old 10-28-09, 04:03 PM   #18 (permalink)
Stand and deliver
roscoFJ73's Avatar
There is no doubt the 3F is silky smooth at low rpm,but the cost of runing diesel more than makes up for it
Mr Rentokill
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 11-01-09, 03:58 AM   #19 (permalink)
Hulsty's Avatar
Spent the long weekend so far making up some new door trims and install a cd player and speakers, they came out pretty well I recokon. Also fitted up my winch bar. Pretty pleased with the approach angle now, with the 35''s on the shackles will hardly get in the way.
Old 11-01-09, 11:20 PM   #20 (permalink)
mmmmmm
BeratE is offline   Reply With Quote
Old 11-02-09, 07:31 PM   #21 (permalink)
JuanJ's Avatar
Hello,
Looking good. One mean rig you got...
How much did you move the front axle? 30 mm like in the Red Barron?
JuanJ
2006 FZJ71 - Purebred.
Mostly stock. GPS, Air Compressor, Cooler
JuanJ is offline   Reply With Quote
Old 11-03-09, 03:34 AM   #22 (permalink)
Hulsty's Avatar
This one is about 30mm forward, 25mm on the spring perch and a little from the springs, as they are for a 4'' lift which make them longer than stock. Unfortunately the tyres rub BADLY on the front
Old 11-03-09, 09:33 AM   #23 (permalink)
Gib009's Avatar
such a neat looking middy mate! Red Barrons looking in a bit of a sorry state though. What gauges have you got on the dash?
