Old 10-09-09, 04:41 PM   #1 (permalink)
Natty's Avatar
Question : Annoying Squeal
Annoying squeal from the rear end of by BJ73, prominent when reversing. Put the rear end up on jacks, put it in gear and spun the wheels back and forth, I would suspect rear input bearing but to methe sound seems to resonate from the driveshaft, cant say for sure its the rear bearing? Any ideas? At first i thought it was a clutch issue but it isnt...
1987 BJ73 - 3B, OME, 34" skinny Swampers, PTO, rear Aussie
1990 HDJ81 - mint & stock - grocery getter
Natty is offline   Reply With Quote
Old 10-09-09, 05:15 PM   #2 (permalink)
inkpot's Avatar
TLCA# 10338
Howdy! I'd grease up the ujoints and slip joint on the DS, and check fluid levels in the transfer and rear diff. If that makes no difference, then look into the rear brakes. John
85 Toyota mini truck for chase/support!
CSC #41
inkpot is offline   Reply With Quote
Old 10-09-09, 08:14 PM   #3 (permalink)
Natty's Avatar
...just a dry u-joint, hahaha guess its time to grease this thing eh?
Old 10-09-09, 08:54 PM   #4 (permalink)
beislebub's Avatar
I had the exact same thing happen to me on my Toyota P/U, the problem was fixed with about 20-30 pumps of grease in the drive shaft slip joint.
Joel.
beislebub is offline   Reply With Quote
