Old 10-01-09, 09:11 PM   #1 (permalink)
Rookie
TLCA# 19935
Block Heater - KZ-TE
I read a thread about block heaters and can't seem to find it now. Long and short, I am looking for a block heater for my LJ78. In north Toronto in farm country without a garage so I think it will be prudent.
Any idea on the part number?
Other options? i.e. the radiator hose type - again, I read this in a posting some time ago but didn't save the post. Doh!
PS I do recall that from a previous posting that the frost plug was behind the starter, is that the case on the LJ78? I am pulling the starter tomorrow to have it rebuilt... getting the dreaded clicking and have had it continue to over crank without stopping now a couple of times. On it's way out from my assessment.
Perhaps this should be a separate post.... thanks again.
kzj78 is offline   Reply With Quote
Old 10-01-09, 11:08 PM   #2 (permalink)
Stand and deliver
roscoFJ73's Avatar
I dont think the radiator hose type will help because of the thermostat position at the lower coolant inlet.
The 1HZ 1HD T have it in the same position and others report dismal results
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 10-02-09, 06:53 AM   #3 (permalink)
dberwin's Avatar
1991 LJ78 2LTE
I put an inline heater and it did not work just warmed the hose and not the truck.
If you put the block heater in it is under something on the left side (starter I think) LORDCO part number 3100019 400W block heater. I put mine in while appart and you use the rear plug on the block.
1991 Prado RHD
Cache Creek, British Columbia
Canada
http://www3.telus.net/public/berwin01/
Or my other hobby
www.ocis.net/tvsac/
dberwin is offline   Reply With Quote
Old 10-05-09, 08:08 PM   #4 (permalink)
I have a rad hose heater in my 90 prado that works well in the alberta cold. There are a few threads about block heater vs rad hose heater at the toy diesel forum
Block Heater install - ToyotaDiesel.com
grease_guzzler is offline   Reply With Quote
