09-28-09, 05:41 AM
5th Gear problems H55F popping out
Hi All,
Recently bought a BJ74 with a H55F, gearbox works well but on overrun in 5th it pops out of gear. When under load its holds 5th fine, but if you back right off completely it pops about halfway out of gear and free revs.
Any ideas what the problem could be? Has done about 310,000km It kinda feels like the gear doesnt fully engage when put into 5th, like the gear stick doesnt move as far as my FJ73.
Could it be a shifter problem? Or should I pull the box and have it rebuilt?
The Red Barron - FJ73 - FOR SALE! Inquire via PM
The Silver Bullet - BJ74
09-28-09, 05:46 AM
Sounds like your going to have to go into the trans. for some work. MIke
Mike Hanson
1982 FJ40
1987 FJ60
3 x 1988 FJ62
1989 FJ62
1991 FJ80
09-28-09, 06:26 AM
Stand and deliver
It could be worn out shift forks and a bad detente spring. Not sure if you can get the top cover off with the trans in place though.
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
HJ61 with slidin windas  regrettfully SOLD:(
Holden Commodore V6
Honda XR650L
09-28-09, 07:06 AM
My H55F did exactly the same - at about 110 000miles. Cost me a full overhaul - all bearings and seals replaced. An old LC hand told me years later that replacing the pilot bearing - needle rollers - would give you another 10000 miles before needing more work...
09-28-09, 04:05 PM
Usually there is too much end play on the mainshaft,mostly countershaft because of wornout bearings.
Simon
09-28-09, 06:27 PM
I heard H55F's are prone to this, I read somewhere that you can heat the fork and bend slightly inward or somnething to that effect and it would stop that from happening?
R
06/1983 RHD Turboed BJ42 LX, Triple wipers, P/S, A/C, 5 spd H55F, ARB Lockers, factory 6 seater!
CDN M101 Military camping trailer w/ RTT
10-01-09, 06:39 AM
that advice came from me years ago, fromt he factory the fork does nto fully engage the tiny teeth area of the 5th gear.
you will not need a full overhaul. contact Dan at 4 wheel and he can sell you a kit to fix this problem.
cheers
10-01-09, 06:49 AM
thanks crushers, thats what I thought upon reading your older posts.
What are the contact details? google ing 4 wheel comes up with a million hits
10-01-09, 07:55 AM
JonB ke6gfb
87 bj70, turboed, 35'ed, arb'ed, slidered, winched, 4x4llabs rear bumper & arb front, HF'ed & VHF'ed.
97 40th fzj80 w/difflocks, cdl switch & pin 7 mod, Hanna sliders, 2.5" ome lift, 1" body lift, rear drawer system on 285/75-16's.
87 sas 4runner- air lockers, dual cases, beadlocked 35" mtr's, waggy & cheby springs, sliders, 8274 winch, etc...sold to build a heep.
