Water sedimenter - separator
I Read several thing on this at this moment in that forum... I ask that question in a other thread... but I suppose the question fall between two chair ...
OK : My separator is by pass. I whant to plug it back. So... I plug it back and that's it ? Do I have to care TO CLEAN IT ? I suppose yes ? Pass so diesel in ? I suppose I found some residus inside ? Some procedure before plug it back ? __________________ BJ42 1982 * The Primitive Beast BJ70 1985 * The Green Machine 1992*Corolla*All-trac* The Quiet Spirit Si je dois aller en enfer... ce sera en Landcruiser (Canadian french guy (Québécois)... sorry for my english ! ) http://forum.ih8mud.com/showpost.php...79&postcount=2 |
#2 | |
You can take the seperator off, unscrew the top, and inspect/clean it. Do not be suprised if you see a little rust in the bottom (from water that sat and was not drained). Put it all back together (make sure the o-ring goes back in as well) mount on the frame rail and hook up your fuel lines. Hook up the lead to the filter light in the dash (make sure it's working). There is an in and out, and I can not recall if they are marked. hth's gb |
[You can take the seperator off, unscrew the top, and inspect/clean it]
Oh yeah ? it seem hard to unscrew the top. Realy ? I havbe already try... but meaby I don't try anought hard ? You talk about the top with the two line on ? AND - Do I have to fill it with diesel befor start the truck... or bleed the line with the srew near the diesel filter ? Thank, that help. __________________ BJ42 1982 * The Primitive Beast BJ70 1985 * The Green Machine 1992*Corolla*All-trac* The Quiet Spirit Si je dois aller en enfer... ce sera en Landcruiser (Canadian french guy (Québécois)... sorry for my english ! ) http://forum.ih8mud.com/showpost.php...79&postcount=2 |
Yes, I have taken one apart before, cleaned, inspected and put back together. It will unscrew. Sure, can't hurt to fill it with clean diesel before you put it back on the frame rail. You should change your fuel filter (If it has not been done lately) and bleed the entire system before firing it up anyway.
gb |
Loans | Credit Card | Remortgaging | Nissan Titan Performance Parts | Debt Consolidation |
