09-07-09, 03:23 AM
Difference between Diff-lock and hub-locks PLEASE!!!!
i have driven my 80 in all sorts of tropical terrain and used the diff-locks, but the KZJ71 is new to me and i have been told that the diff lock is different from hub locks..... iam confused please some one tell me how to use the hublocks..............
-HDJ81 with ARB lockers, PIAA lighting
-KZJ71 going through a transformation- Lifts done (more on the list) DAILY RIDE !!!
Iam a former Mitsubishi 4wd fan (those indeed were dark days) who saw the Light and converted to the Toyota Landcruiser and never looked back!!
09-07-09, 10:32 AM
K:
If the hubs are not locked, the front wheels are disconnected from the axles.. Without the hubs locked, you will NEVER have 4WD.
Lock the hubs when you first get off the pavement and you think you may need 4WD - drive as long as you want with the hubs engaged..
If you read your owners manual, typically the manufacturer recommends driving 10% of the time with the hubs engaged.
I engage my hubs in the fall, at the first sign of snow, and dis-engage only when the roads are dry in the spring, or i'm going for a longer trip on the highway.
It is my understanding that most 80's are full-time 4WD, and thus have a differential in the transfer case..
HTH's
'74 Bronco - RIP
'75 FJ40 - Gone
'81 RamCharger - Gone
'95 XJ - recently Gone
'85 SR5 - Going
'90 HZJ73 - 24V winch, Lift, Auto
Reason: grammar
09-07-09, 02:20 PM
hub locks on the KZJ71 will be electric. you CAN NOT engage the hub locks on the 'fly'... you need to be at a complete dead stop.
once the hub locks are engaged then you can shift from 2H to 4H at any speed.
diff lock engages the diff locker
hub lock engages the frotn hubs.
09-07-09, 06:12 PM
Dog is my co-pilot.
Hi All:
Diff Locks are in the axle center sections (aka differentials.)
Hub Locks are at the outer ends of the axle tubes (usually only on the front axle.)
Lock-out Hubs connect or disconnect the wheels from the axle assembly, while a Diff Lock keeps both axle shafts in an axle assembly turning together.
HTH.
Regards,
Alan
www.seattlecruiserheads.com
"Cruiserdrew" wrote:
" The very worst thing you can to to a cruiser is half thought out mods that are underfunded and never quite get finished. Then you end up with hacked junk that doesn't work, and some future owner will curse you and all of your children."
09-09-09, 02:10 AM
guys thanks for the response, i really appreciate the info, its just a smart-elec mechanic told me that i cannot turn my vehicle with hub-locks engaged.... i know that using diff-locks with both rear and front engaged in my 80series all wheels turn at the same rate, so not a wise idea to make full turns...
however i wanted to know if i can turn the 71 around with hub-locks engaged and in 4H....
thanks in advance guys...
09-09-09, 05:42 AM
ummm, if you are in 4H on hard packed surfaces then it is not a wise move to make tight turns.
on loose gravel, dirt, sand, mud, snow, ice, grass then no issue at all.
pavement, hard packed dirt, cement then you are causing severe gear bind and 'CAN' break something... sooner or later.
just saying...
09-09-09, 11:19 PM
Dog is my co-pilot.
Hi All:
X2 what "Crushers" wrote!
Regards,
Alan
just saying...
09-11-09, 04:13 AM
thanks guys...this is the greatest forum...
09-18-09, 08:49 PM
Dog is my co-pilot.
Hi All:
No worries!
Be sure to post pics of your rig!
Regards,
Alan
09-23-09, 03:04 AM
#10 (permalink)
Josie'sLandCruiser, this is after my farm trip a couple of weeks back, now it sits much higher with 80series springs throughout...
09-25-09, 09:59 PM
#11 (permalink)
Dog is my co-pilot.
Cool! Keep those photos coming!
-Alan
09-26-09, 12:35 AM
#12 (permalink)
hey Alan here are some more pics, in this pic the cruiser now has 80series coils all around...
Can't wait to going mudding with the new coils...... wud put up pics of my next farm trip....
09-27-09, 07:36 PM
#13 (permalink)
Dog is my co-pilot.
Hi All:
"Krishanprasad," the KZJ71 looks good sitting on the 80 Series springs!
If you are gonna go "mudding" better fit a set of Simex or Super Swamper mud tires!
Regards,
Alan
09-28-09, 05:00 AM
#14 (permalink)
(cough) tractor tires kick S/S ass (cough)
09-28-09, 09:08 AM
#15 (permalink)
Sure thing, im just trying to get my hands on a set of 35' tractor tires, keeping my fingers crossed........
