Power Steering Gear reman or rebuild?
Well it's time to put the cruiser back on the road. Since I parked it before spring the steering gear has started to seep when it sits, very very slowly but it leaks none the less. When I give it it's run every two weeks it's always in need of fluid.
Now I have to either rebuild it myself or buy a reman (which is more then I wanna spend). I've lurked around the fourms and found a few good write ups on this, but I wanted some to ask about steering play, from what I can see everything up front is good and tight, I replaced my steering shaft/ u joint assembly with a JDM one ( my old one was fubared), also all my ball joints and tierods are good and tight, yet I have a fair amount of play in the wheel around an inch or so... I do think I could use a new steering dampener which is on the list...
I'm wondering if the play could be from the gear itself, and if a rebuild kit will remedy this?
Next I'm wondering where should I buy a rebuild kit from? Anyone have a good source? other than the stealer ship!
thoughts, advice?
1986 BJ70, 24v with a 3B
