LinkBack (3) Thread Tools Display Modes
Old 10-05-08, 07:00 PM   #61 (permalink)
JuanJ's Avatar
Hello Gib009,
Impressive rig. Keep up the good work and keep us posted.
Please let us know about the 1" lift.
JuanJ
2006 FZJ71 - Purebred.
Mostly stock. GPS, Air Compressor, Cooler
JuanJ is offline   Reply With Quote
Old 10-05-08, 11:40 PM   #62 (permalink)
Gib009's Avatar
Cheers bud. Sure will
87 Toyota Landcruiser BJ71 on 35's
Gib009 is offline   Reply With Quote
Old 10-07-08, 11:07 PM   #63 (permalink)
Gib009's Avatar
Check out the article about my truck in 4x4fever.
4X4 Fever - 4WD news, reviews and photos
Old 10-10-08, 10:38 AM   #64 (permalink)
JuanJ's Avatar
Hello Gib009,
I checked the link. Very good! You already have a reputation with your Cruiser, which is good to hear.
Again, keep up with the good work.
JuanJ
Old 10-11-08, 08:48 AM   #65 (permalink)
Gib009's Avatar
Thanks mate not sure about that, just got contacted by the guy who hosts the site and asked to do a survey didnt know it was going into an article. Pretty cool though
Old 11-13-08, 08:37 PM   #66 (permalink)
Gib009's Avatar
Bit of an update:
Longfields are in
Swivel Hub rebuild was done at the same time
Extended the diff breathers to under the bonnet
Lifted the rear (swapped 2 leaves from a 2inch lift 60 rear pack into my existing pack)
Tie rod ends and relay ends are booked to go in today
I just used the old connections for the diff breathers at least they are high up under the bonnet
The redder leaves are the lifted leaves, i am pretty happy how it turned out, it lifted it pretty much exactly the amount i wanted.
Here is how it sits now. Much better
Still to do:
1 or 2inch body lift (still rubs at front when turning and flexing)
Needs some width (rubs slightly at the rear on inside guards)
Im thinking either wheel spacers or more neg offset rims but not sure yet. Does anyone know the widest 15x8 available? Ones i have now are -22mm
Exhaust
Shocks
Convertor
Locker(s)
And i still wouldnt mind extending the wheelbase 3 more inches but ill have to get the front driveshaft lengthend and im not sure how expensive it will be.
Old 11-30-08, 10:36 PM   #67 (permalink)
Gib009's Avatar
Check out me and my truck in this video, 'A day on the dunes' by 4wdtv.
YouTube - Perth Dunes
Old 11-30-08, 11:47 PM   #68 (permalink)
Stand and deliver
roscoFJ73's Avatar
Whats this about a "secret place 100klms north of Perth" ? Looked like good ol Lancelin to me
Great video,good to see some local territory on yootube now and again
Have you colour co ordinated your shovel like Ken Ramsey.
I saw his shiny waeco blue shovel at the 4wd show a couple of weeks back.
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 12-01-08, 12:21 AM   #69 (permalink)
Gib009's Avatar
Nope it was Ledge point. That main dune has got to be steeper and taller than the biggest one in lano. Steepest dune i have ever been down actually quite scary in the shorty thats why i didnt go up it!! Real nice drive i am going to camp in the dunes there soon the beach was real nice too.
Lol yeah the blue 'waeco shovel' how is that advertising at its best.
Come to think of it i havnt got a shovel in my shorty must get one
Old 12-04-08, 10:51 PM   #70 (permalink)
Rookie
great vid Graham -- lots of shots of your rig nice! I've republished it on my site. Geez WA is an awesome spot
4x4Fever is offline   Reply With Quote
Old 12-05-08, 07:22 PM   #71 (permalink)
Gib009's Avatar
Thanks Shayne. Nice writeup! Ill keep you posted with part 2 once its completed
Old 12-06-08, 03:29 AM   #72 (permalink)
Hi Graham,
Here's a shot of the BJ74 before the 1" and a bit body lift:
Its got 15x8 Alloys turning 33x12.5x15 Cooper STT's. Since the pick i have also put on 2 inch wheel spacers. The spacers are the reason for the the body lift cause the tyres are scrubbing on the rear of the front guards at full lock.
The reason I used the wheel spacers was that the rims and tyres were chewing out the boots on the tie rod ends and on the left side the steering arm from the knuckle had ground off parts of the weights for the wheel balance. Not pretty! When I did the knuckle rebuild the passenger side was the worst. The knuckle bearings were badly worn and the steering arms were loose.
After the knuckle rebuild and tie rod end and draglink replacement my steering was pretty bad so I went and got a wheel alignment. These guys reckond they knew about 4x4's....what a joke. They reckon I needed to adjust my castor. Thanks to the local 4x4 shop the problem was diagnosed as the bushes on the suspension were knackerd and the draglinks a bit loose. Replace and tighten and everything is sweet.
The body lift went well.... no worries. The Cruiser has a smoother ride now I reckon. The only thing that needed adjustment was the earth lead from the battery to the engine, pretty tight, and the PTO selector stick in the cab doesn't quite slip into gear. Should be fixed with some boot cutting. I didn't have to reposition the radiator shroud which I thought I may have to do.
Next is to move the front diff forward to clear the wheel arches. It still rubs a tiny bit and off road I would be ripping the flares and mud flaps off. Next set of tyres will probly be 10.5 not 12.5 and with a front diff move should be sweet as.
Cheers Mate,
Thanks for the info and I like your rig.
Gav.
gav_bj73 is offline   Reply With Quote
Old 12-07-08, 07:12 AM   #73 (permalink)
Gib009's Avatar
Hi gav nice looking 74 you have there. How anoying is it once you do one thing you always have to do something else to counter the problems caused by the thing in the first place! How much body lift did you do and is that picture with the BL in? Nah i say keep the 12.5's i would even say next set go 35's. Once you relocate your diff forward and your body lift then i dont think you will have a problem. No point in going 10.5's unless your going back to 31's.
Old 12-08-08, 05:04 AM   #74 (permalink)
Hi Graham,
Got the photos post lift and spacers. Rides better and looks meaner.
This is how the front mount looks. I kept the lower rubber mount to act as a shock absorber and switched out the top rubber mounts for the new poly body blocks.
The lift went well and it was pretty easy. 2 inches would definitely require new flexible brake and cluch hoses, radiator shroud repositioning, gear stick mods and possibly fuel filler lengthening... possible other stuff. 1" is easy. 120 bucks all up.
The spacers have caused the bulk of the problems. They have made the front wheels rub. The lift has eased some of the pain but I still need the front diff moved.
Speaking of every mod requires 3 mods to fix the first 1..... Did u have any probs or other issue moving your diff? The steering geometry would be the same on our cruisers so I thought I'd ask. Do u just redrill the diff mounts and bolt it back together and your right to go.
Cheers mate.
Let me know how u get on with the build up.
Gav.
Old 12-08-08, 08:57 AM   #75 (permalink)
Gib009's Avatar
Hi gav, you have got me thinking with that 1inch lift. I might try it, i am having problems sourcing the front two bolts what length bolts did you need? I read on this site that i need 220mm (for the front two, and 150mm for the back ones) for a 2inch lift so i will just need 195mm bolts for a 1inch lift is that right? What size where your other bolts at the back. I may try the 1inch first and then if thats not enough i can always put the factory mounts on + the 2inch blocks... a bit more work but it will be worth it because i am not keen on the 2inch BL i just want 'enough' and nothing more.
Also i am thinking of getting spacers, what problems are you having? I might try the 1inch spacers thats all i really need to get the rear wheels out from the chassis a bit.
No probs moving front diff, only i had to loosen, twist and retighten a clamp on the steering arms (see 'how to fit 35's on a bj74' thread) because it was just nicking the dirt of the other steering arm. Like i said in the pm as long as you dont go over 25mm you will be fine.
Old 12-09-08, 04:53 AM   #76 (permalink)
Hey mate,
I pretty sure the bolts I used were 200mm for the front and 175mm for the rest. What I did was replace the mounts on one side then take the bolts down to the local bolt shop and bought the bolts + 1" or as close as I could get. I ended up using nylock nuts too. The original set up has a retaining nut and a locking nut so using nylock nuts will reduce the amount of thread you will have to use on the bolts. All the bolts I got fitted well and weren't poking out beyond the chasis mount.
As I said in a previous post I discarded the top mount and used the bottom one as the shock absorber for the body. The only thing you would have to do if you reused the original mount is to drill out the new blocks to fit the crush sleeves that are on the stock ones (see previous post photos) or cut the crush sleeves off cause they may not fit otherwise. The front mounts are actually set up differently to all the other ones but this is no concern when doing the lift.
As far as spacers go you shouldn't have any probs with the back. It may effect the articulation of the back suspension tho cause once the tyre is out past the rear fender it might hit the fender before the bumpstop does its thing. At the front is were i have had issues with the 33x12.5 and I reckon your tyres might rub too. A couple of things you have going for u is the extended shackles and the 1" diff move.
Do the extended shackles give much lift? I want to get some of these too. I need more room for tyres up front. A spring reversal could be an option on the front for me. I haven't measured mine yet but on some suspension set ups if you reverse the front springs u can move your front diff forward. This would probly cause probs with the steering and then I would have to mess about with that as well.
Just trying to find the easiest option to fit the tyres really.
Hope the mods are going good Graham. If you haven't sourced the body blocks yet let me know and you can checkout were I orded mine from as they were good quality and real good value.
Gav.
Old 12-09-08, 06:22 AM   #77 (permalink)
Gib009's Avatar
Hi mate thanks for the info. Yes i have 8 2inch body blocks i got them from ebay for about 70bucks shipped. Hmm i might look for 200mm bolts then see if i have any luck. I already have 6 150mm bolts i just dont want to start ripping things out and then not be able to finish it.
The extended shackles gave me barely any lift because i had such saggy springs. If yours are in good nick they should give you 1inch lift i probably got about 10mm.
Yep a spring reversal will move the diff forward about 45mm which will make the steering arms interfere with one another. Just redrill the spring perch it is real easy and it will give you heaps more room.
Thanks mate i have to say your 74 is looking mean as with that stance.
Old 12-09-08, 07:06 AM   #78 (permalink)
Hey mate,
I had 10 body mounts under mine. The shorty must have 8 aye...
Do you have a bolt shop near you. I have a bolts and fasteners shop in town and thats all they do. I'm there all the time getting stuff to replace the old stuff and for installing new bits in the cruiser. The ones for the front must be pretty big cause the guy at the shop was like, wow do you really need a bolt that long. Anyway they had them, the high tension 8.8 or whatever. I was gonna buy them before hand but your better of getting the ones off your cruiser and taking them down the shops and using them as a reference for the new ones. Just to be sure. might save some muckin around. Cost me about 35 bucks for bolts and nuts.....
Hope it all goes well. Keep me up to date and I'll let you know how I go.
Cheers,
Gav.
Old 12-09-08, 07:29 AM
gav_bj73
This message has been deleted by gav_bj73.
Old 12-10-08, 02:48 AM   #79 (permalink)
Gib009's Avatar
Yeah i have a few bolt shops that specialise in just fasteners and they didnt have the longer ones that i needed. Ill get onto it this weekend, i might do what you say and just bring the bolts to a shop and get exactly 1inch longer.
Right now im totally rewiring the convertor, the last one i drowned because it was screwed to the floor and all the wiring is a mess. I think ill just rip it all out and start again
Old 12-10-08, 03:33 AM   #80 (permalink)
Stand and deliver
roscoFJ73's Avatar
Originally Posted by gav_bj73 View Post
Hey mate,
Cheers,
Gav.
Try West Coast Fasteners in Balcatta,thats where the auto parts shops shop
Mr Rentokill
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 12-10-08, 04:24 AM   #81 (permalink)
Gib009's Avatar
Already tried them rosco! Them and about 5 other places. Then again i think ill try them again i think they did 200mm bolts in a m10 which would suit for a 1inch lift but i did need 220 for the 2inch.
Old 12-10-08, 06:02 AM
gav_bj73
Old 12-10-08, 06:05 AM   #82 (permalink)
Hey Graham,
Have you got a new converter yet? I love converters....
Here is my set up. 24V dual batts. Run the engel for a week.
Starters
To Redarc
To Aux Batts
Monitor the state of charge through this
Convert it to 12V from this
So I can use stuff like this
I run every thing off the converter. Stereo, CB,Fridge, Water Pump for Glind, Reverse/Camp Light, 12V plugs etc...
Works good.
The previous owner has wired the stereo between the 24V starters and I found that just before the battries !@#%! themselves. The way it is now there isnt much running of the starters. Just lights.
You can buy kits but I decided to do a custom job on mine. Cost more but I have exactly what I want.
Cheers
Gav.
Old 12-10-08, 07:54 AM   #83 (permalink)
Gib009's Avatar
Wow great setup! Your exactly the man i want to talk to. I have actually been asking questions on another forum about convertor setups and how i should wire mine as i havnt got a clue. Yes i did have a convertor a pretty good one a redarc 30A continuous which worked fine but i drove a pretty deep water crossing and flooded it. I now have a 20A continuous 25amp peak one which seems ok. I started taking the old one out and the wiring was a mess and i couldnt trace back what the previous owner was doing so i think ill just start again.I want to run my cd player, uhf radio and 1x 12v cigarette lighter for small stuff like mp3 player etc
Do you mind explaining/drawing me up a quick wiring diagram because i cant find ANYTHING on the whole internet. I also have one of these things from the previous setup
Oh and also where and how much does it cost for one of those electronic voltage displays that would be very handy because i think mine are unbalanced most of the time.
Cheers mate
Old 12-11-08, 04:11 AM   #84 (permalink)
Hi mate,
My converter is running off the aux batts but you will be able to use yours off your starting batteries. Take power from the + and - terminals that are the furthest apart. If you have anything coming off the battery terminals in between these you will fry your batteries. If you have a multi-meter use it to check the volts on your batteries. Check them indivdually as 2 12v batteries and then as a 24v battery. The difference in volts between the 2 12v batteries should be minimal. It is +/- 0.1 volts on mine. I check mine once a week cause of the probs I've had in the past. There all good now but I dont want to buy anymore batteries for a while so I check'em
It should be easy to wire. Make sure you put in a fuse. I put in a 15 amp and my converter has a built in fuse as well. Might be a bit of over kill but I would hate the cruiser to burn to the ground. I have run wires through to the cabin off the staring batteries through where the aircon pipes go, they come out at the top of the passenger foot well. I put a piece of coathanger through the hole with a loop in it and pulled the wires through. Much easier. 20 amp continuous should be plenty for what your running.
You have accessories and power wires on you stereo and/or cb , yellow and red I think. I wired these both into the power from the converter. I took me a while to work it out. It wont work if you dont. The only drawback it that the memory wont work on the stereo, unless you leave the converter on all the time, so everytme you turn it on you'll have to eq it. I wouldn't leave the converter on all the time, I just dont trust it. Dont want fires.
Where to mount it? Get it up high. I've got a cargo barrier so I'm gonna mount it on that, up high, just behind the passenger seat so I can switch it on and off without to much mucking around. At the moment its behind the centre console on the ground.
Knocked up this diagram today. Hope it helps.
Tomorrow I'm doing the front diff. I think I need a 12mm drill bit, can you remember what u used? Cant wait to stop those tyres rubbing. I've been doing 10 point turns all week.
Cheers mate, if you have any other questions let me know. Its good to find someone doing similar mods so we can trade info. Gotta love 24V tho. Less current draw so your electrical stuff will run heaps longer on the same power. Much more efficient.
Gav.
Old 12-11-08, 05:50 PM
gav_bj73
This message has been deleted by gav_bj73. Reason: dodgy link
Old 12-11-08, 05:54 PM   #85 (permalink)
Oh... and here's where I got the voltmeter. Might be local to you.
Dual Battery monitor/ Dual DC Volt meter/ 4wd / caravan - eBay Other Solar Panels, Solar Panels, Gadgets, Electronics. (end time 18-Dec-08 22:15:52 AEDST)
Cheers
Old 12-12-08, 12:36 AM   #86 (permalink)
Gib009's Avatar
hey thanks gav. Is it similar without the aux batteries? And how do you wire in multiple accesories to the single outlet from the convertor? Let me know how your diff relocation goes. Yes i agree its very handy having somone interested in similar mods. I am thinking of mounting my convertor on my dash so i can easily turn it on and off and it is nice and high up. Just not sure about the heat from the sun if i leave it outside. The other possibility is on the rasied platform on the floor inbetween the seats but its not so high up then. I did my BL last night 2inchs it looks tall! Ill post details next post.
Old 12-12-08, 01:07 AM   #87 (permalink)
Gib009's Avatar
I did my body lift last night. Spent half the day deciding 1inch or 2inch and the number of ways i could do it but i decided to just do the extra few things required for the 2inch and have done with it. I think all rubbing apart from the rear wheels on the chassis is gone. And it actually looks like the tyres fit now.
I knew 1inch BL required no modification of the fan shroud, so for 2inch i decided to move the shroud down 1inch and so far so good no sounds of smashing fan blades. I just took the shroud off (mission) and drilled each hole 1inch down, i also had to cut out some holes for the pipework in the way below the radiator.
This is how it looks fitted but i will cover the hole with some angle iron riveted to the shroud to keep the air flow as normal as possible.
With the lifted radiator i may be able to squeeze the PTO winch shaft over the crossmember for a much higher winch
And here is how she sits now
From a recent flex test i may need to extend my bumpstops maybe an inch shouldnt be to much trouble and then measure for shocks.
I also think my guards have enough room for 1inch spacers without further cutting. But knowing me ill probably get the 2inch spacers and try deal with it later.
Old 12-12-08, 01:15 AM   #88 (permalink)
Mall Cruiser
1loudLX's Avatar
TLCA# I NO HAZ K?
I just smiled on those last two pictures, looks mean! Love it.
2000 Lexus LX470 - There's a mod list growing
2005 Specialized FSR XC - Needs new home
2008 Scott Gambler FR10
- Nut up or shut up
1loudLX is offline   Reply With Quote
Old 12-12-08, 07:43 PM   #89 (permalink)
Gib009's Avatar
thanks mate
Old 12-13-08, 02:44 AM   #90 (permalink)
Hi Graham,
I ran a positive and negitive from the converter to behind the dash. I made all my connections to the 12v accessories from this power. I crimped all my connections so they dont come lose.
This is how I split the power.
There are other connectors that I use to join the wires. They are much better than what is in the picture. They are a double ended connector. You just put the wires in each end of the connectors and crimp them with the crimping tool. If you go down to JayCar or similar electical store you will see them in the same spot as you find the connectors in the picture.
I saw the fuse box in one of your pictures. I tried that for a while but found that it was not the best option for me. My converter already has a fuse and auto cut out and if you also put an inline auto fuse on the power coming out you will not have a problem if something shorts out cause one of the fuses will blow before your gear gets fried.
Hope that helps.
The lift looks awesome mate. Mad.
What u got planned next
Its been raining the last couple of days and cause I work on the cruiser outside I havent had a chance to do the diff yet. Monday....
Gav.
LinkBack to this Thread: http://forum.ih8mud.com/70-series-tech/241664-mighty-short-cruiser.html
Posted By For Type Date
Off-roaders Club Forum > ????? ?????? This thread Refback 07-19-09 11:04 AM
LAND CRUSER 7X - Off-roaders Club Forum This thread Refback 06-28-09 12:04 PM
????? ?????? - Off-roaders Club Forum This thread Refback 06-24-09 02:48 AM
İ2000-2009 by IH8MUD Inc. - ALL RIGHTS RESERVED
