Old 09-09-08, 07:10 AM   #1 (permalink)
LiaU79's Avatar
Question 1HDT into BJ70/LJ71
hi there ..
i already do a lot of searching .. maybe my searching is not hard enough but ..
i even could not find thread about people put 1HDT into their BJ70/LJ70/LJ71 ..
last week .. i already blown my 2LT (overboost).. and now i wonder if i could use this engine (1HDT)..
if i can .. what manual tranny could i use an d fit into BJ70/LJ70/LJ71 ? or should i use the automatic trans ?
or should i just put in 13BT as here is hard to find 14BT available .. i think it already gone in other people rigs ..
friends .. give me an ideas or suggestions .. please ..
LJ70, 5L engine + turbo + intercooler/ 38mm tial wastegate / 33x12.50x15MT kumho / custom made stainless steel snorkel / hella rallye 2000 lights / rancho rs9000 x / kings springs / polyutherine bush kits / temp+volt+boost gauges /
LiaU79 is offline   Reply With Quote
Old 09-09-08, 07:19 AM   #2 (permalink)
LiaU79's Avatar
honestly saying here .. i already tried my friends' rigs ..
1KZTE is quite ok and i know it is a straight bolt on my ride ..
i dont like it ..
even my other friends already have the 1KZTE .. they dont use the ECU and changed using mechanical fuel pump from 14BT ..
and still i dont like it..
the feeling is just like the power of my old 2LT with bigger turbo and fuel pump and etc ..
do i have any other options?
Old 09-09-08, 08:54 AM   #3 (permalink)
crushers's Avatar
check out coldtaco's LJ78 build with the HDT install...
do a search HDT LJ78
the start to the above truck here: http://forum.ih8mud.com/70-series-te...uck-build.html
shit all flows down hill and pools around your feet. The object is to
keep shovelling it away. If the shit is gaining you better figure out
how to shovel faster :-) Dave Stedman 03/20/09
(for any of you going through a divorce, thanks Woody) http://forum.ih8mud.com/1650867-post1.html
Wayne in Ontario
www.luxuryimports.ca
Old 09-09-08, 02:01 PM   #4 (permalink)
coldtaco's Avatar
Hi,
I haven't started an official thread yet on my project, but here are some basics that I have found/done.
First, you will need a longer nose, that is, one from a heavy duty 70 series, the one with the more square front end, not the rounded front with the light duty 70 series. I am using my front end from my BJ-70 on a LJ-78. The front body mounts/radiator mount are different from a heavy duty vs light duty 70.
I am using a 1HD-FT with it's matching 5 speed and full time transfer case out of a 80 series. Problem I have is that the shifter for the transfer case is in the way of the floor, so I unbolted it and now it looks like the drive train fits just about right. What I will do is get the shifter assembly from a part time transfer case, HF1A, and use it. You will need new engine mounts and insulator for a HZ application in a 70 series, so you need the mounts that bolt to the block and the weld on mounts to the frame. You may need a HZ or HD specific radiator out of a 70 series. Also, you may need to change the air cleaner to work for this engine, I haven't gotten to that part yet. IF you are left hand drive you will maybe have to figure out the throttle cable routing to make it work, I haven't gotten to that part either yet. So basically you should probably use a H151 type manual transmission with a HF1A part time transfer case. I don't know if you can use a automatic out of a 80 series with the HF1A since I am not going this way.
This should give you some thing to think about
Hybrid in progress
For Sale; 13B-T/H55F
24V Warn 8274
Dobinson 70 series leaf lift kit
coldtaco is offline   Reply With Quote
Old 09-09-08, 10:39 PM   #5 (permalink)
LiaU79's Avatar
here in my place, I never seen BJ70/LJ70/LJ71 fitting in 1HDT or 1HDFT 24 valve engine into their rigs .. maybe there are but .. never encounter them personally ..
one of my friend (owner of kinaway auto parts dealer).. we call him Mr. Siow and he own a BJ74 .. he is part of the competitor for the Borneo 4x4 International Challenge here in my place ..
last time he put in 15B turboed into his BJ74 .. and this year .. he already changed his 15BT engine to 1HDT. . he put the 15BT into his another car .. he use it
there is many prado here .. LJ78 .. LJ70 .. and other .. but BJ70 is one or two only .. hard to find .. i also dont know why ..
i know BJ74 and BJ70 is not the same .. but .. in term of engine bay .. is it same?
if same .. maybe i can upgade my LJ70 to BJ7?
Old 09-10-08, 12:02 AM   #6 (permalink)
coldtaco's Avatar
A BJ-70 has the same front clip as a BJ-74 as a BJ-75 or any other heavy duty 70 series. All the older heavy duty 70 series had leaf springs where the light duty had coil spring. Newer model heavy duty 70 series have coil in the front and leaf in the rear.
Like I mentioned before, the light duty 70 has a shorter engine compartment and different front body/radiator support mounts compared to the heavy duty. You need the extra room if you want to install a six cylinder whether it is the HD or HZ.
Hybrid in progress
24V Warn 8274
Old 09-11-08, 04:00 AM   #7 (permalink)
LiaU79's Avatar
yupp..
thanks a lot for the sharing guys..
this afternoon i just found the suitable front design for my LJ..
i got the chrome grill design from .. BJ73 if i dont hear it wrong..
now .. my question is should i change to leaf spring if i select 1HDT as my new engine? or should i stick to my coil springs ..
now i'm using kings spring which labelled KTRR-42 .. i dont know what it mean ..
any ideas?
Old 09-11-08, 04:28 AM   #8 (permalink)
crushers's Avatar
stick with the coils, why take a step back in the evolution chain?
Wayne in Ontario
Old 09-11-08, 11:57 AM   #9 (permalink)
coldtaco's Avatar
You do understand that you need more than a front grill off of a BJ-73?
Hybrid in progress
24V Warn 8274
Old 09-11-08, 04:35 PM   #10 (permalink)
LiaU79's Avatar
yupp .. i bought a half cut of the BJ's ..
which previously have the 13BT in it together with the trans .. pedals .. dashboard .. 24 volt wiring ..
but without the original wide chrome bumper which have the place of a winch ..
i let it down first because it cost me more $$ ..
forgot to tell that here we are right sided driver ..
Old 09-17-09, 07:53 AM   #11 (permalink)
Rookie
Heres a link to outerlimits4x4.com (aussie site) with my build up of a 1hd-ft into my 70 series..
http://www.outerlimits4x4.com/ftopic...php&highlight=
been meaning to do a members build on here but never find the time!
happy to help if you've got q's.
dan
PZJ70 is offline   Reply With Quote
Old 09-17-09, 08:19 PM   #12 (permalink)
beislebub's Avatar
You'll also have to move the front cross member forward, to clear the fan and rad.
I put a hz into my lj78, there's a build thread under " hz into a lj78"
Joel.
beislebub is offline   Reply With Quote
Old 09-19-09, 02:02 PM   #13 (permalink)
lulo's Avatar
Exclamation
... x2
My next engine: 1KZ-T
LULO Adventure
Land Cruiser LJ-70`88 "El Niño"
A Coruña - España (Spain)
"Eres lo que has viajado"
My Cruiser "El Niño": http://forum.ih8mud.com/70-series-te...o-lj-70-a.html
LULO - Photos: http://www.flickr.com/photos/lulo_adventure/
lulo is offline   Reply With Quote
Old 09-19-09, 06:56 PM   #14 (permalink)
Clint79's Avatar
I dont think leafs are a step back in the evolution chain for 7x series cruisers if both set ups come out on the vehicle, i think its different horses for different courses
J7
Clint79 is offline   Reply With Quote
Old 09-19-09, 07:03 PM   #15 (permalink)
crushers's Avatar
think what you will ... the 79 has coil up front, now why would Toyota do that?
Wayne in Ontario
Old 09-20-09, 07:04 AM   #16 (permalink)
Clint79's Avatar
the same reason they have leaf in the back still.
J7
Old 09-20-09, 07:06 AM   #17 (permalink)
crushers's Avatar
load capacity?
Wayne in Ontario
Old 09-20-09, 07:07 AM   #18 (permalink)
crushers's Avatar
(you know, if we ever got together over a beer, i think it would be an interesting night)
Wayne in Ontario
Old 09-20-09, 07:33 AM   #19 (permalink)
Clint79's Avatar
load capacity?
like i mentioned mate you wouldnt go by a 80 series if you needed to carry loads of bricks all day ,you could use it ,,but a 75 or so would be suited better in saying thats why i think different horses for different courses coils might be better for comfort and flex but leafs are better for heavy loads yada yada thats just my thoughts
Yes mate there would def be some very interesting cruiser/beer chit chat
J7
Old 09-20-09, 06:33 PM   #20 (permalink)
JuanJ's Avatar
Hello,
Heavy loads make riding in a Cruiser more comfortable, too...
I agree, different applications require different systems.
JuanJ
2006 FZJ71 - Purebred.
Mostly stock. GPS, Air Compressor, Cooler
JuanJ is offline   Reply With Quote
Old 09-20-09, 08:23 PM   #21 (permalink)
Stand and deliver
roscoFJ73's Avatar
So they wouldnt be the last work ute in the world with leaf springs all round
I think the coils up front and the leaves in the back is a good concept for HD vehicle intended to carry heavy loads .
Its interesting that the Patrol cab chassis were offered with either a rear coil ,or rear leaf.
Landrover Defender went to coils all round in their cc
Mr Rentokill
FJ73+1HZ Diesel NEW GEARBOX
33 in BFG A/T
Holden Commodore V6
Honda XR650L
Old 09-21-09, 04:35 AM   #22 (permalink)
crushers's Avatar
just playing devils advocate...
Wayne in Ontario
