2lt engine rebuild or swap
Has anyone rebuilt a 2lt? Have an approximate cost on parts?
I have a '89 LJ73. My #2 piston is pushing 50 lbs the rest are hitting 400+. Is there a bolt in replacement diesel (or gasser). I was told a 3b would require replacing the tranny. I believe the tranny is a r150 Thanks |
Diesel Trucker
Any idea whats wrong with it? With that much difference it might be a bad valve.
Have you tried to put air pressure in that cyl with the valves closed? Also, if you add oil to the cyl and it has little affect it could indicate a bad valve. The cylinder would have to be extremely bad for oil to not make a difference. Id test it out then pull the head. You could bolt in a 22R or pickup V6. They came with R trans, but I have no idea if the input shafts are the same. You should at least be able to swap the LJ transfer case over to one of these though so long as it has an r150-1. Not sure about the mounts, but you would probably have to change those for the gassers. Sorry not much help. |
#3 | |
Diesel for blood
There are also 3L, 5L and 5LE,which are versions similar to yours but no factory turbo on them as far as I know. Your tranny info is on the aluminium plate on the firewall. I would have guessed it to be a R151 ![]() The 3B requires a lot of work as it is tall and the light duty Landcruisers like yours have the bonnet sloping down at a greater angle to meet up with the shorter front end Another option which is potentialy a lot of work ,is the 2.8 HS diesel. Latest reports are that the supply has dried up. I think the rebuild kts are about $1000 AUD or less. Try aussie ebay for a price . But I would try and diagnose the exact problem with existing engine 1st
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
It's the piston that's bad. Did the compression test with adding oil and got 80 psi. Also, there is severe blow by.
Team Bullsac
To add.
I helped Orange crate compression test his 2LT. We also did a leak down. Definately the bore/piston/piston rings. |
is this johns?
Is the wall scored bad on that one cyl? I'd try replacing that piston and rings. Couldn't hurt and not all that expensive. __________________ 1964 FJ40 | 1966 M416 | 1976 FJ40 | 1985 BJ70 Volvo Power| 1997 FZJ80 | TDI commuter car Rising Sun; Former CLCC You should be able to delete your own thread. Communists abound
It is John's. What's the best way to break the ridge to get the piston out?
Use a ridge reemer to take the ridge out. On just about every 2lt I have seen apart develop a fair sized ridge on the top of the block. Depending if they had a previous head gasket failure the top of the bore on the block gets pitted
__________________ 2.5 OME Heavy coils, ARB rear locker PRADO STOLEN ![]() 89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
I guess that is the reason it was farting along so slow during Cruise Moab! BTW this is Matt, good to see ya on the board! Your LJ, as you know, is known to be in the "Light Duty" series of Land Cruisers and share many minitruck components on the running gear/chassis. So a 3B is not a direct swap but a 22R-E might be worth looking into, though the conversion from diesel to gas plus all the other issues would make it a substantial swap. I know Toyota made an RJ73 though, so maybe the motor mounts etc. are similar?
__________________ Matt Miller '77 FJ40 2F "Brahma" + Lockright, Warn 8274! (?07K) '91 2wd Toyota pickup 22R-E (202K) Rising Sun Rising Sun Bio |
#10 |
Guess I decided what to do
Picked up a 22re with 102,000 miles on it. complete with ECU, harness, air cleaner , cat and gas tank. $600 The question now is does that bolt to my R151 or do I need advance adapter? Hi Matt. What are you doing in the 70 pages |
#11 |
Diesel Trucker
#12 |
Diesel Trucker
I got curious and looked in the EPC . The RJ70 and LJ70 show different input shafts for the trans.
#13 |
Cruisers are in my blood, and the 70 series is in my sights!
#14 |
What's EPC ?
#15 |
Electronic parts catalog.
I have an earlier CD version, but it does not cover LJs. There was a group of guys trying to create an online version some time back. I'm not sure how successful they were. Search EPC in thread titles. Last edited by spotcruiser; 06-05-08 at 08:00 AM. |
#16 |
Sorry to hear the diesel go
![]() A little search on the internet (especially at Toyota truck websites) should help you figure out which engine/tranny combos are easily done. Those minitruck guys have it all figured out lol. It may be correct that the R151 was available with the 3.0 V6 and the 22RT-E (turbo'd 22R-E), while the W56 (?) was available with the standard 22R-E (but maybe only on 2wd models). I don't know, I'm gonna shut up, but Wes and I talked about it briefly last night and when you consider that you could drop your oil pan and pull the head, hone the cylinders and replace some rings and that would take care of 90+% of your problem, that sounds a lot easier/better than doing an engine/electronics swap! __________________ Matt Miller '77 FJ40 2F "Brahma" + Lockright, Warn 8274! (?07K) '91 2wd Toyota pickup 22R-E (202K) Rising Sun Rising Sun Bio |
#17 |
Never did like that engine. I don't usually follow the path of least resistance. Character flaw?
Debt Consolidation | Finance News | Daily Horoscopes | Personal Finance | Personal Loan |
