Hi guys this is it this is her problems
well this is my 75 series land cruiser on 35's with camo paint and a 1hz 1997 :P bucket seats problems searing pulls to left had fire under dash no lights wont charge alt no ignition ahah need a new harness running on jump starts and diesel solinoid :P gutless as all 1hz that have done 330'000k x mining vehicle so it's had a good life :P im in perth wa and spend just about every long weekend in lanclen apprentice diesel mechanic with westrac |
pulls to the right:
dragging brake worn wheel bearing tire pressure incorrect alignment incorect bent frame (unlikely) cool ride, turbo it and you will breath new life back into the old girl... of course do a compression test first. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 Wayne Owen Sound Ontario http://www.ivoac.ca separating the rumours from the truth. join today |
did you fit the bucket seats ? if so ,what brand and did you have any troubles doing so? i wanna put some in mine
I have Scheel seats in mine,easy fit can take pics if you need.Its only flat bar and 1'' rhs and engineered RTA's idea not mine.
#5 | |
Diesel for blood
Steering pulling to the left is normal to some extent. By that I mean if you get on a straight road it will veer off because of the camber over a few hundred metres. If your fighting the wheel then its probably in the steering alignemnent or the things Crushers said Malaga Suspension are good with landcruisers ![]() If its down on power it could be pump or injector related,or even be due for a valve adjustment. I think I saw your unique camo job in Lancelin once ![]() I like to go up there myself now and again and do a run up to Wedge Island or go onto Cervantes. What caused the fire under the dash? __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Give me a week ,I'm going fishing when I get back I'll take some photos.
You guys seem to know ur shiz
im going 2 drop by ape suspension and get them to sort it out well they decided being a mining vehicle they dont need fused headlights ..(being on a crappy ..ignition lights on setup ) so went in a puddle and came out on fire .(bit of a wierd..thing but ..funny ..untill i have to rewire it ;P |
OK bolting in seats
i wish i left my bench seat where it was but changing drivers seat u have 2 make a fair few brackets i bolted my toyota seat rails onto the seat ..with a little bit of drill work then just extended the right bracket out a bit ...about 10ml to the right good fun :S |
Debt Consolidation | Remortgages | Teaching the Trivium | Loans | Ringtones |
