Whats limiting my flex ?
G'day all,
On my RHD FJ73 I have done a RUF, today I took out the shock absorber and the swaybar link to see how much flex I can get, I got a fair bit I think for a SUA setup. In the pics the front wheel is just off the ground while the opposing side is hard on the bumpstop. Question is, looking at the shackle I could probably get more flex but the tyre didnt want to do down anymore and I dont know why? The brake lines, driveshaft etc are on the compressed side so wont affect drop. All I could think of was that I have maxed out the steering links ? Any help appreciated. Also I measure what size shocks I need with stock towers, compressed ~410mm Extended ~ 660mm And rancho make a RS5000 that is compressed 400mm extended 686mm beatuy! ![]() ![]()
__________________ Aussie FJ73 middy turning 33'' claws |
Diesel for blood
To be honest they dont look too bad to me. Any more flex and they would rub.
Your next step is a SOA if want more. IMO leave it as it is and concentrate on getting lockers __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL Last edited by roscoFJ73; 05-31-08 at 05:24 AM. |
thats pretty damn acceptable to me...
nice ride. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
I think I will leave it, shocks probably only cost about 300, all other options will be more. From what I have found out its probably the bushes limiting me. Whats best to run rubber or plastic style ones? currently got plastic style ones. As for rubbing, the 33'' JUST clear with the guards chopped 50mm on the front with the inner guard raised. My 35'' will rub though, might need to get the mash hammer out.
cheers Now I need to work on the rear!! Anyone know a longer standard spring that fits ? I tried a IFS lux spring, about 30mm to long and 75 series springs need mounts moved which I dont think I want to do, to much hassle I think. __________________ Aussie FJ73 middy turning 33'' claws |
Rubber bushings are more compliant and therefore usually allow more "flex."
__________________ 98 LX470 85 BJ70 |
i always recommend the rubber vs that poly shit. rubber has lasted 15-20 years in our cruisers but a daily driven cruiser 'might' get 3-5 years out of poly bushings.
poly wears poly can have an irritating "squeek" poly limits flex poly is what the cool guys run. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#7 | |
cheers __________________ Aussie FJ73 middy turning 33'' claws |
That is pretty DAM good to me also. I must be cool cause I run polly LOL
__________________ 2.5 OME Heavy coils, ARB rear locker PRADO STOLEN ![]() 89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
I'm yet to flex it up on the drivers side, but I think the front drive shaft will run on the cross member since its fairly tight in there, what have people done to alleviate this ?
#10 |
The best source for rubber bushes that fit and don't cost to much is Toyota.
And if you have to swap out your springs once a year to pass inspection they will not stick to the pins on you. __________________ Importer and distributor |
#11 |
ok, I'm alittle confused. Is it a budget reason you want more flex?
Just so you know, IMO, traction would cure all your "flex" problems. Personally I'd move that winch guard up, it looks like it's killing you on approach. Then I'd go with traction. "Flex" IMO as opposed to traction is highly overrated. Looks good enough to me...? Don't get me wrong, I love a droopy suspension. But is there ever really enough flex? Then it comes to a point you needing to do something else. __________________ "Let me have a Diablo sandwich, a Dr.Pepper...and make it fast, I'm in a *** **** hurry..." ... "You want sumpin?" "hush puppies daddy" "We got no time for that ****!" |
#12 | |
you have a rhd correct? if so then you will not rub the driveshaft since it is above the crossmember...droop could be compromised ont ehdrivers side due to the driveshaft and crossmember connecting... __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
#13 |
Hulsty What happened to the Simex tires you got recently?
#14 | |
And I like having my tyres on the ground rather than an unstable rig with tyres flapping in the breeze. __________________ Aussie FJ73 middy turning 33'' claws |
#15 | |
#16 |
In the shed, I dont use them to drive to work on!! The maxxis go pretty good for easy weekends and daily driving
#17 |
hey mate, whats RUF? and howd you get such good flex?
#18 |
Couple of questions Hulsty
I take it that ur running rear 60 series springs up front? Is it simply a in and out process and are extended shackles advisable? ftx-runner. __________________ 87 4runner ![]() 86 BJ74 LX
#19 |
Hey mate, I used 60series/middy rears. I used the main and wrap leaves combined with 5 leaves from my original 2'' lifted front back and another 60 leaf mixed in to hold the front up. All the springs I used were well used so if you used new stuff would probably need less leafs. You will need 2'' anti inversion shackles otherwise they wont fit!
#20 |
Here are some more pics mate
MPAA | Art visionaries | Debt Settlement | Mortgage Calculator | Loans |
