Go Back   IH8MUD™ Forums > Toyota Tech Forums > 70-Series Tech
Old 05-22-08, 10:50 PM   #1
dberwin's Avatar
My new Guages in 91 Prado
Just had to put something cool and liked these. The only problem is they flash on low temp but you could use the dial guages if you like with a high temp limit. They are from prosport and the service and pricing is excellent.
Prosport Gauges
I got one extra sending unit ($9) and have put one in the Transmission and one in the rad hose. The rad hose addaptor was from the same company. The switch above the guages is to switch from one to the other of the sending units. The EGT went into the old EGR port in the exhaust.
The guages are Oil and Water temp, Boost, and EGT
Daniel
1991 Prado RHD
Cache Creek, British Columbia
Canada
http://www3.telus.net/public/berwin01/
Or my other hobby
www.ocis.net/tvsac/
dberwin is offline   Reply With Quote
Old 05-24-08, 11:37 AM   #2
prado t's Avatar
TLCA# 17424
I just noticed your Boost is 22lbs and exhaust is 148 x 10f = 1480 that is pretty HOT isnt it?
2.5 OME Heavy coils, ARB rear locker PRADO STOLEN
89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
prado t is offline   Reply With Quote
Old 05-24-08, 07:50 PM   #3
Z()LTAN's Avatar
that cant be right... you should have melted the block by then... 600 is close to melting pistons
Lock, Stomp and Steer, No Fear
Z()LTAN is offline   Reply With Quote
Old 05-25-08, 10:26 AM   #4
pradocruzer's Avatar
Hey dberwin, nice gauge set up. I have a cheap digital temp gauge but it sucks. Do your gauges change with the turn on of head lights, heater fan, ect?? I have checked my engine temps with a heat temp gun and the gauge is always out.
I am emailing Prosport and asking questions but I wanted to know first-hand.
Thanks.
pradocruzer is offline   Reply With Quote
Old 05-26-08, 07:24 AM   #5
dberwin's Avatar
Too High temps
The gauges are just cycling through when I turned it on. It was sitting in my shop so just turned the key on and took the picture. The Boost runs 9 psi, EGT as high as 1200 and the coolant at 150. Those are in F deg not C deg. so taking some time to get used to them.
No changes with other electrical things that I noticed.
I would get the Blue Dial ones if I had the choice now so take a look at them.
Dan
1991 Prado RHD
Canada
Or my other hobby
www.ocis.net/tvsac/
Advertising | Mobile Phones | Northern Rock | NJ CoLocation | Credit Counseling
