HZJ 78 turbo diesel No staying power
Hello there you lot.
I have a HZJ 78 Turbo diesel troop carrier which has done about 130000 kms in the NT of Australia. I put a safari turbo on about 5 yrs ago and it has been going like a rocket. Over the last few months I have been having power and rev troubles. Vehicle will start off at about 120 to 130kms an hour, at about 2900 revs. Slowly but surely the vehicle will slow down till I can only achieve 2000 revs in all gears so reducing speed to about 80kmh esp while towing my boat. I have changed fuel filters, mucked around checking there is no air in the system by opening an injector etc, but all to no avail. Any one able to offer me a hand here? Its peak barra season and traveling 400 ks at 80 kmh is not fun. Thanks |
#2 | |
Diesel for blood
Yours sounds a bit young for pump problems,but it has the symptoms. The everyday high speed wont help ![]() I would also check the mesh filter in the pump where the fuel line plugs in and the fuel pick up in the tank __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
do what Rosco says and i have had great results in adding a feeder fuel pump to my turbo systems.
right now your pump has to pull and push, the feeder pump allows the original fuel pump to just feed...big difference. |
Wayne, what kind of fuel pump are you using?
__________________ Louis Join the True North Toyota Land Cruiser Club in Ottawa http://toyotalandcruiser.blogspot.com/ Join the IVOAC here to keep JDM's coming - www.ivoac.ca Dealers join the CAVI to protect your rights - and keep the JDM's coming- www.CAVI.ca |
i will have to go look but it was a generic from NAPA... 12V.
i put one on the HZJTI40 i am building and WOW!! it moves nicely. |
Thanks gents
Thanks for the info gents. i will give both theories a go.
#7 | |
Here is an old thread which has some interesting links to discussions from 4-7 years ago from around the world on pusher pumps on the 1HD-T. Same idea for the 1HZ. http://forum.ih8mud.com/diesel-tech-...mp-walbro.html hth's gb __________________ WANT A TOYOTA DIESEL ENGINE? Join the Import Vehicle Owners Association of Canada: Fight for what is right Canadian Vehicle Importers and Suppliers: Join the CAVI TLCA#7091 Last edited by Greg_B; 05-17-08 at 10:33 AM. |
it's fishing time!
am i right in thinking that this extra inline pump can alleviate the strain on my 13bt factory pump and thus increase the performance of my 13bt?
#9 | |
Where this seems the right thing to do is with the rotory pumps. Especially the Bosch VE style. There are a number of reasons, one of which is the rotory pump uses fuels as the lubricant, unlike the inline...which use engine oil. Apparently you don't want too much pressure...a couple lbs post filter and pre pump is supposed to be the ticket. hth's gb |
#10 |
Diesel Trucker
Ive never tried a pusher pump with the rotary or the inline pump, but if you pump the primer on the inline while it is running the idle speed increases... Maybe too much pressure could cause over-fueling?
#11 | |
hth's gb |
#12 | |
Reliable Diesel Fuel injection is the name of the place he has thousands of rebuilts in stock as well as new, injectors, you name it. Here is the number 02 9548 2380 NSW Cheers, Michael |
#13 | |
Diesel for blood
My local diesel shop says it is usually the plunger that goes 1st. Then all the bits that are connected to it go next. The vehicles from up north(here) with the long hot roads tend to wear their pumps out quicker __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#14 |
Michael, did you replace the pump yourself ot have someone do it for you?
Louis __________________ Louis Join the True North Toyota Land Cruiser Club in Ottawa http://toyotalandcruiser.blogspot.com/ Join the IVOAC here to keep JDM's coming - www.ivoac.ca Dealers join the CAVI to protect your rights - and keep the JDM's coming- www.CAVI.ca |
#15 | |
![]() I think a 1HZ is pretty easy to change out. Cheers, Michael |
#16 |
OK, thanks veyr much - I thought so. I'll be replacing mine soon.
Thanks again. Louis __________________ Louis Join the True North Toyota Land Cruiser Club in Ottawa http://toyotalandcruiser.blogspot.com/ Join the IVOAC here to keep JDM's coming - www.ivoac.ca Dealers join the CAVI to protect your rights - and keep the JDM's coming- www.CAVI.ca |
#17 | |
Diesel for blood
If this is the case ,use the best puller you can find. The shop that loaned me a puller said its best to get the puller tight till it starts to bend and hit the pump shaft with a hammer and drift. Of course you may have dream run like tlcruiserman ![]() __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#18 |
Run, Fuel Conditioner all the time and your pump whether it is inline or a radial will last the life of the BLOCK , Most VE style pumps ie 6BT C had lift pumps before the radial they were a Diaphram type that ran off of the camshaft
__________________ 2.5 OME Heavy coils, ARB rear locker PRADO STOLEN ![]() 89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
#19 | |
. I pulled the one on my 99' P/U first because that one still has no front clip on it, so I can get to everything really easy, then did the 97' Troopy and it was a bit tight with that puller on the front, but ended up working ok. When I swapped them out again, I did not even need the puller.On another note I found the changes to the timing cover and idler for the 99' and up model a welcom improvement over the older version, I think the tensioner works like it should with the new design, the old one ended up sticking and not holding very well under heavy excelleration. I also like the bolts instead of clips for the entire timing cover. Cheers, Michael |
#20 | |
Cheers, Michael |
#21 | |
Diesel for blood
Havent had a chance to look at the new type of tensioner __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Car Insurance | Bad Credit Mortgages | Loans | Internet Advertising | MPAA |
