Detailed Gearbox and transfer case specs
Does anyone have or know where I can find Detailed Gearbox and transfer case specs relating to gear ratios and when they were manufactured and what countries they ended up in ?
I'm wanting to know the ratios for my H55F and transfer case in a 85 aus spec middy with a carby 3F and what other H55F/A440 transfercase ratios there are. I've found two low ratios 1.959, and 2.488 but not sure what cars had what and if i've already got the 2.488 ratio low range cheers __________________ Aussie FJ73 middy turning 33'' claws |
the H55F was bolted to a 1.9 gear case
the auto was bolted to either 2.3 or 2.488 AFAIK the 2.48 came only behind the HJ60 auto and the 80 series... as for a site you could try Under Construction . there are a few errors but very few... |
It just that this site suggests otherwise, that that "early" and "late" H55F's had either a 1.9 or 2.488 low range. NOt sure what I've got and weather its worth me trying for 2.488.
cheers That link didnt work for me? just a error site came up ? __________________ Aussie FJ73 middy turning 33'' claws |
wait, I am wrong, just checked my own link. A H151F behind a 3F has a 2.488 low. And all the H55Fs mentioned have 1.9 low
#5 | |
Diesel for blood
TLC FAQ - 8.1 Transmission & transfer Case Ratios (All :1) I wonder if the low ratio of 2.296 has the 38mm idler shaft and the 1.9 has the 34mm? __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
I was just reading about the idler shaft dia change on the marks website, on their site it says that the change was 10/84. I'm kinda hoping I can swap A440F low range of 2.488 into my transfer case. Alot cheap/easier than diff gears or marks gears.
Mortgage | Webmaster Forums | Credit Card | Loans | American Flags |
