Go Back   IH8MUD™ Forums > Toyota Tech Forums > 70-Series Tech
Old 05-06-08, 10:29 AM   #1
bj71 is on a distinguished road
Engine won't shut 0ff
Hi there....My engine will not always shut off on my BJ71, and when it happens the clutch gets really stiff. I understand that there is a switch on the engine itself that cuts off the air supply, and then shuts down the engine. Does anyone know where the switch is?
bj71 is offline   Reply With Quote
Old 05-06-08, 11:10 AM   #2
canucksafari's Avatar
canucksafari is on a distinguished road
Its likely your EDIC. Maybe it is just a dirty or loose connection if it is an intermitent problem. Search or do a post in the diesel section.
Old 05-06-08, 11:44 AM   #3
Greg_B's Avatar
TLCA# 7091
Greg_B is an unknown quantity at this point
Originally Posted by bj71 View Post
Hi there....My engine will not always shut off on my BJ71, and when it happens the clutch gets really stiff. I understand that there is a switch on the engine itself that cuts off the air supply, and then shuts down the engine. Does anyone know where the switch is? Thanks
Your 13BT used a VSV which is located on the left side of the engine block, rear.
If you don't have the 3B/13BT manual either down load it from links off this site, or buy a copy. Follow the trouble shooting process with the VSV.
The VSV uses the vacuum system, same as your vacuum assisted clutch.
May be the VSV, but I think an intermittent vacuum leak. Either way, follow the manuals process and that should point direction.
hth's
gb
Old 05-06-08, 03:41 PM   #4
oldblue's Avatar
oldblue is on a distinguished road
Read thru this, it helped me to fix my problem.
http://forum.ih8mud.com/diesel-tech-...p-13b-t-2.html
Prado, Electric to Manual Hub conversions.[ Your Own Hubs ]
oldblue@clear.net.nz
oldblue is offline   Reply With Quote
Old 05-07-08, 01:37 PM   #5
Thanks. I appreciate the help.
Problem Mortgage | Credit Cards | Mortgages | Online Loans | Mortgages
