BJ74 auto gearbox drama
Hi
Just currently my BJ74 is not dropping into the last gear when im on the open road. So at 100km it is revving around 2 1/4 instead of 1 1/2. Just wondering if this is bad bad news, or something that can be fixed easily through an auto gearbox specialist. Any help would be appreciated. Last edited by bj74noob; 04-23-08 at 08:52 AM. |
is your fluid level good?
__________________ 1986 BJ70, 24v with a 3B |
Yes, if anything the level is a touch over. It's never leaked.
did you have any work done on your cruiser shortly before this started happening?
have you been abusing or towing with your truck just before this happened? does the fluid smell burnt? is it red or brown in colour? |
#5 | |
Diesel for blood
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
On my BJ74 with auto at 100kmh indicated the tach is 2200 rpm in 4th locked up. Seems about right to me - I couldn't imagine how sluggish it would be at 1500 rpm. Can anyone confirm what is correct?
__________________ Graeme '89 BJ74 auto, stock '90 JDM Carib/Corolla 4WD wagon |
2250 at 100km Cmon guys it supposed to be doing that, unless I missed something,( Rosco) you should have caught that! Wayne must be waking up, Graeme good Job!
__________________ 2.5 OME Heavy coils, ARB rear locker PRADO STOLEN ![]() 89 BJ74 ARB lockers front and rear 4" ZEAL lift, 24v M8000 winch ARB bull bar, Marks 108 to 1 HI 305 to 1 low
Yeah well for some reason mine used to drop back to low revs. It would be a bit sluggish at 90kmhr but cruising at 100 or more. Currently the gears change 3 times. 2 1/4 revs may sound the norm, but it sounds like its revving more than it should, a bit like when you put the foot down to overtake and it drops back - thats what it sounds like.
#9 | |
Diesel for blood
#10 |
Apparently the lock down function doesn't work (thats what the pros said, not that I know what that means)
Could just be a spring or something. |
#11 |
1st to 2nd
2nd to 3rd 3rd to overdrive ________________ 3 changes. you are fine. the A440F has 3 gears and 1 overdrive. __________________ turboed 84HJ60, in San Diego. |
#12 | |
Diesel for blood
When you get to highway speed the convertor physically connects the engine to the drive so you are no longer using the hydrulic system in the transmission. Download the free 84-90 body chassis manual and read up the auto transmission fault diagnosis. Im sure it will mention it. My bet is the trans will have to come out,but they would have mentioned that already ![]() __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
#13 |
Loans | Loans | Loans | Loans for people with bad credit | Credit Card Consolidation |
