effects of elevation change
Hello all, i just moved from sea level to about 1600ft. above sea level and now i am having trouble starting my prado. Is this b/c of the elevation change and if so how would I fix that?
Diesel for blood
If its 10 degrees cooler at that altitude,my guess would be the temperature.It doesnt take much.
Need more info about your Prados starting habits and which engine. Does it run rough and smooth out after a while or does it crank over and take a while to fire ? __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
Beagles Rule!
Don't know anything about a Prado but you do loose 3% of power for every 1,000 increase in elevation. Low compression units have a harder time starting at higher elevation do to the reduction in atmospheric pressure.
You should not notice any change with only a 1,600 increase in elevation from sea level. In a nut shell, elevation is not your problem. __________________ Cruiser Dan at American Toyota Phone is 1-800-432-6668 ext. 8 (I am not cruiser Dan) FJ40.5 Build - http://forum.ih8mud.com/hardcore-cor...ly-begins.html http://www.fcfabrication.com/ |
i would gamble it is the temp change. elevation will not affect the starting, it will affect the performance, fuel economy but not starting since starting is controlled by glow timing, battery strength (speed of rotation), compression ratio and fuel supply...
disconnect the glow plug water temp sensor on the side of the engine to have full glow time duration and see if that helps. __________________ pulling this info out of my ass so take it with a pound of salt "People are poor because they don't spend money wisely, tough sh!t !!! " John Galt 09/22/08 "educate yourself. Sorry if that seems too blunt." John Galt 11-01-08 Wayne in Ontario http://www.ivoac.ca join today |
American Flags | Loans | Mortgage | Credit Card Consolidation | Exchange Newsgroups |
