Location: Campbell River BC on Vancouver Island in Canada on Earth
bj74 springs in a 60?
hey, i got some new'ish 90000k springs out of a bj74 wan was installing them to find out the backs work but the frunts a 44mm longer then my 60 springs.
bla bla bla so if i moved my frunt shackle mount 44mm forward on the frame would the spring work and hold the front of my rig? could someone give me the center to center spring mount measurement, from center of front spring pin to center of the rear spring pin. thanx Les __________________ BJ60 TURBO 3B ,2 1/4" exaust pipe, Custom rear frame and 33x12.5/r15 Hankook Dynamic MT, bj74 springs frunt and rear, fixed 90% of body rust and painted metallic money green and truckbed liner. her name is "The Screaming Green Submarine" |
If this is the way you're thinking about it, I'd advise no.
If you want to though, judging by the state of your rig you need to know how the radial angle of the spring will play into the placement of shackles. Are you building the truck around the springs, or the springs around the truck If its the first than go nuts, if its the latter, than do some digging and figure out the proper way to do it. __________________ --- 1986 BJ70 w/ OME - soon to be locked & loaded. 1982 BJ42 Stock w/ 84000km original clicks (soon to have OME) currently in "tear down" |
well its that, i cut and move the mounts a bit, taking 1 - 1.5 hrs or i unbolt all the shit and use the 2 main leaves from the old spring packs and the rest of the new spring packs. and that will take way longer
Coupon | Adverse Credit Remortgage | MPAA | Get Rid of Debt | Personal Loans |
