FJ73 engine change
Do know anyone who has done a conversion with a 1fzfe toyota engine into a 1986 FJ73 landcruiser currently with a 3f engine and a 5spd manual gearbox. I would like to retain the manual gearbox if possible and bolt the engine in using a flywheel adapter or something similar.
any help would be much appreciated cheers justin |
Diesel for blood
Hi Justin .I suspect it would be a whole lot easier to use the H150 gearbox that the early 80 series had and sell your old 5 sp.
__________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
would you recomend using the standard transfercase or the 80 series one?
#4 | |
Diesel for blood
I think you would need the t/case that comes with the 80 series gearbox. I would get underneath a FZJ75(not easy to find) or a HDJ78/79 and have a good look. I think the gearstick positions in the floor are pretty close to the older types like your 73 From memory they use some linkage trickery to exit the floor in the same place Car yards are the best place for researching engine swaps
Synchronization fast and easy | Mortgages | Mortgage Calculator | Web Hosting Service | Car Credit |
