1000000
hi guys , just a quick question. my lj78 just hit 100000kl and t-belt light came on. Im sure it must just be a light telling you to change timing belt , mine was done about a year and half ago. when the head was done. Is there some way that i can turn of the light . Thanks for your imput.
#2 | |
Diesel for blood
They have a small rubber plug on the speedo glass. Remove and poke something small into the hole to reset it. __________________ HZJ75 cab chassis 95 model ,stocker FJ73+1HZ Diesel NEW GEARBOX 1HZ =same power as 3F with 30% better fuel economy 2in Dobinsons lift.Powerdown adj shocks 33 in BFG A/T HJ61 with slidin windas regrettfully SOLD:(Volvo 740 GL |
thank you rosco
good to know as I just did my t-belt too and I'm reading 98,000 kms
Be aware that if you reset the light it won't come up again untill another 100.000 has passed.
So if the belt was replaced at e.g 85.000 k then you should replace it at 185.000 k but the light will come on when you hit 200.000. They should have reset the light when they swapped the belt. So if you do so at 185.000 (example!!!) then reset the light although it's still off. Next time (at 285.000 k) it will show. So if RHD Toyota's resets his light now at 98.000 k it will show again at 198.000. __________________ Ron R 1995 HZJ-73 4.2ltr Diesel; ARB-lockers front and rear ; MM-hydr.winch 10,500#; home made sliders; HST-Parabolic springs; Koni Heavy Track shocks. http://www.ourwebspot.nl/English_index.html |
Cheap Magazine Subscriptions | Credit | Credit Reports | Internet Advertising | Debt Help |
